Page 11 of 11 FirstFirst ... 91011
Results 101 to 106 of 106
Thread: Installation of 220V downlights
  1. #101
    Jul 2008
    Germiston, South Africa
    Quote Originally Posted by SparkyScott View Post
    What about click flow connectors?
    Are those available in South Africa? I also came across this from Hager but I don't know if it's available in South Africa or neither
  2. #102
    Jul 2008
    Well a friend of mine has found the following connector box. It is 65mm in diameter so I'm not sure if it will fit into a standard hole made for a downlight, what is the standard cut out size?
    The thing I'm not to happy about is that the method of holding the cable secure is a rubber seal, one on each off the four entries, which is cut in half and one half is in the top of the connector box, and that comes together with the second half, which is mounted in the other half of the connector box.
    There doesn't appear to be much protection against stain on the cable but in reality, how much strain is there when using a pvc push in gland with no glue and finger - tightened.
    Here is the link to the manufacturer, SA product nogal, and a picture
    https://ripbox.co.za/
  3. #103
    planet earth
    I would hate to try connect more than 2 cables into the rip box.
  4. #104
    Mar 2019
    East london
    Saw the rip box at ARB.
    They cost more than double the price of a GU10 lamp holder with bracket and block, so what's the point.
    Another thing. If you secure the rip box with a screw, make your connection inside and pop on the lid, you ain't gonna be able to open it again, unless you break it in the process. There's no way you gonna get a screwdriver into the slot to twist the lid open.
    Not for me, thank you
    Cheers and peace out ... Derek
  5. #105
    Jul 2008
    The point is that the light fitting you mentioned is fitted with a connection box and not a junction box. Pictures attached.
    Even the connection box on the fitting mentioned has no way of terminating the cable on the sheathing as required by SANS.
  6. #106
    Mar 2019
    East london
    Google https://www.google.com/search?q=gu10...hrome&ie=UTF-8
    https://greenlightonline.co.za/produ...BoCTuwQAvD_BwE
    Check the first photo on left. Perfect with facility to secure the sheath at R19.
    That's the one I use.
  1. Electrical Installation Costs
    By Tracsec in forum Electrical Contracting Industry Forum
    Last Post: 28-Jul-22, 05:38 AM
  2. [Article] New electrical installation regulations
  3. Zen cart installation tips
    By garthu in forum Technology Forum
    Last Post: 13-Aug-10, 11:55 AM
  4. Who may work on an electrical installation?
    By douw in forum Electrical Contracting Industry Forum
    Last Post: 16-Apr-10, 11:57 AM
  5. new installation
    Last Post: 18-Feb-10, 01:34 PM
