Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Porcupine problem
  1. #11
    Platinum Member desA's Avatar
    South East Asia
    @desA, Are you talking about a HV electric fence type unit? The sleeves are lying on the floor, won't the system just earth? I don't know how you could keep the wires insulated.
    If the ground is reasonably moist, then you only need the live carrier - use the ground as return. As long as the live line is kept off the ground, it should be fine. I'd make a few pipe sleeves/insulators to keep it on top of your water pipes.
    An alternative is to even use a few lightly-clad lines running over your pipes. When porky bites again, it will get the full knock of the energiser on the first decent bite. In this case, use ground as the return - this is standard practice on farms.
    You could use a smallish energiser - they are not that pricey. Give a nasty kick.
    AndyD (23-Mar-10)
  3. #12
    South East Asia
    Quote Originally Posted by daveob View Post
    also found this blog via google :
    http://rouxpecans.com/blog/?paged=3
    seems that all you need is some smelly stuff to ward them off.
    What under-arm deo does this Julius Malema character use?
  4. #13
    Quote Originally Posted by desA View Post
    Thanks for the suggestion (wasn't sure at first if you were being serious). I'll definitely look into it.
  5. #14
    Diamond Member wynn's Avatar
    Oct 2006
    east london
    Would lifting the pipe and cable off the surface be a solution?
    Depending on height required simply bend a pigs tail to one end of a length of rebar, drive the rebar into the ground next to the pipe/cable, lift and clip it into the pigs tail. support if necessary.
  6. Thank given for this post:
    AndyD (23-Mar-10), desA (24-Mar-10)
  7. #15
    Nice idea Wynn, I hadn't thought of elevating the pipes. I'm not sure if the buggers can climb or fly though.
  8. #16
    South East Asia
    Quote Originally Posted by wynn View Post
    Are you a part-time farmer?
    Stunning idea.
  1. Problem getting rid of mites in home
    By Jeff in forum Pest Control Industry Forum
    Last Post: 02-Apr-21, 08:04 PM
  2. HSPDA problem
    Last Post: 11-Feb-08, 09:11 PM
  3. [Article] The Phoenix Checklist
    By Vincent in forum Entrepreneurship and Business Management Forum
    Last Post: 02-Feb-08, 07:12 AM
  4. Motherboard Problem
    By Dave S in forum Technology Forum
    Last Post: 07-Oct-07, 11:12 AM
  5. Telkom technical joke?
    Last Post: 02-Jun-06, 10:01 AM
Tags for this Thread
