It seems upgrading old gel and AGM batteries and adding solar panels to 24 VDC Axpert inverters has become the most common request.
I am currently busy with a Must PV1800 VHM series inverter.
Can we install solar panels and will it save money or just create another expensive to the budget?
Looking at the inverter Solar charger:
Max VOC - 145VDC
PV voltage range 30-130 VDC
PV input power - 1440 Watt
Max charge current - 60 amps
Efficiency - 98%
The most important information is the VOC = 145 VDC, what does it mean, when all the panels are installed and not connect to the inverter at any time of day or weather condition, the voltage cannot exceed 145VDC, otherwise it will damage the MPPT. if you decide to use 4 x 330 watt panels in parallel with a VOC of 35 VOC each, then 35X4 = 1320 Watts
Then we look at the max power of the panels, you add up the power 1440/330= 4,2 panels.
How efficient will they be, that will be determined by many factors, like roof angle, direction, etc.
Should we consider the voltage range? 30-130VDC, would the VOC of 140 VOC be too high, it shouldn't.
