Results 21 to 30 of 31
Thread: Solar panel design and installation
  1. #21
    Mar 2019
    East london
    @GCE
    Do I understand you correctly ?
    If I were in PE and lets say, hypothetically, I install a system big enough to supply my needs without having to use any mains power, my monthly availability fee will be R147 + vat irrespective of the size of my system.
    I'm only using this hypothetical example to understand the system used for availability charges.
  2. #22
    @GCE
    Correct
    I sit at my office with that account - I imported 70 units and exported 89 at peak rates which nullified the import and just paid availability for the month - Install the system in 2014 upgraded battery to a Tesla in 2019
    We set up the inverters to fed back into the grid during peak times as the rate to fed is higher than what we use in off peak times to charge the battery
    I have a client that uses 600Kwh , Buys 212Kwh at off peak , sells 462 KWH back to grid mainly peak and month end elec bill is R 147 + vat
    PE is way ahead when it comes to rates etc - Only problem is that there is a back log of over a year for meters from them so sitting with frustrated clients , one of them being me for home.
  3. #23
    Mar 2019
    East london
    Thank you GCE.
    That sounds fair enough.
    If that's how it works then it makes sense to install something that will deliver as close as possible to one's overall needs, or maybe a bit more and still have the availability of munic power for battery charging during the bad solar periods.
  4. #24
    Mar 2022
    Let me start by saying, I haven't personally registered a system yet. It is a lot of hear say.
    It seems at this point in time there is a lot of speculation, I am not aware of one domestic installation that has been registered, complete with the correct meter.
    I am not aware of any public awareness programs currently running to educate the public on how what to do with a solar system of their property.
    I have noticed there has been an upgrade to the website.
    https://www.durban.gov.za/pages/residents/energy-office
    Trying to figure out what to do is like a maize for me at the moment, just imagine what it must be like for the man on the street trying to figure out what to do.
    It is time to employ a person to manage registrations, this is going to become big business. I dont have time to try figure out what is going on, the website keeps updating, unless you follow it on a daily basis, it will be difficult to keep up. I have around 15 site that require registration.
  5. #25
    Mar 2022
    Attached is the 2023/2024 (1/07/2023-31/06/2024)
    With reference to scale 3/4 residential tariff
    The one that affects domestic dwelling sin suburbs.
    Page 14 - Feed in tariff R1.44 inc vat
    What referred to as the ancillary network charge (based on the inverter per month) - R126-86 per kw. An 8 kw inverter will cost you R1014.88 per month. This is why I want to get one of the 3.5 kw units from the UK, they can handle 7 Kwp of solar, R444.01 per month That all I need for my house.
    For now I believe people of eThekwini are waiting for a the council to roll out the public awareness program and hoping the grace period for registration.
    I am told that there are a couple of domestic installations which are registered , but not meters to fit on their property.
    https://www.durban.gov.za/storage/Do...ff%20Rates.pdf
    They say load shedding will end before 2025, I see there are nuclear power plants in discussion at the moment.
    I also hear comments about stage 1- 16 load shedding, its hard to believe anything, rumors spread faster than wild fires.
    My aim at the moment is to get solar solar installed so that I dont have to worry about eskom or our failing electrical infrastructure and everyone I know is going large with water storage and booster pumps.
  6. #26
    How long does it take to build a power plant?
    Nuclear reactors connected to the grid in 2022 had a median construction time of 89 months or almost 7.5 years. During the period in consideration, the median construction time for nuclear reactors was the longest for reactors connected between 1996 and 2000, at 120 months.09 Jan 2024
    So the fact that they are being discussed does not mean it will clear the problem in 6 months.
  7. #27
    Mar 2019
    East london
    Are these rates not ONLY applicable if your system is capable of feeding back into the grid ?
    What happens if you have a 5Kw plug and play inverter. Are these rates still applicable ?
  8. #28
    Mar 2022
    This is why I have decided to go all in with solar and large water tanks and booster pumps. My hooks and rails are installed.
  9. #29
    Jun 2020
    Fourways
    Water is going to be the new thing, most people have the solar and or battery backup.
    Again 2days no water for me. It happens about once a month.
    The things we do to just live is crazy and get the Gov. Want their share of what they can't supply.
    No wonder all my mates have left and my wife's mates and family have left the country.
    Not always greener but Fuk you can live l.
  10. #30
    Mar 2022
    We are on day 2 of no power, due to 2 MV faults in our area "AGAIN", we are exempt from load shedding due to flooding, the municipal strikes, road repairs (must be election time) damaging cables, you name it. Then we are told that we are back on load shedding, but load shedding is the least of our problems.
    Load shedding might ease but the fact that the infrastructure is failing due to lack of maintenance, all day everyday you see people doing joints in the MV cables.
    You just have to go on holiday for a week to realize how much greener it is on the other side. You just get so use to the crap you put up with here. It will never be greener anywhere for lazy people.
  1. Golf cart solar panel
    Last Post: 03-Apr-24, 02:22 PM
  2. Solar panel safety rating
    Last Post: 05-Feb-23, 06:26 AM
  3. Solar panel wiring. (Question)
    By Derlyn in forum Energy and Resource Conservation Forum
    Last Post: 07-Jun-22, 05:28 AM
  4. [Question] Solar Panel Certificate of Compliance
    By FrancoisERA in forum Electrical Contracting Industry Forum
    Last Post: 16-Jul-21, 04:40 PM
