Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Double insulated solar wires in wireways
  1. #11
    Mar 2022
    712.521.103 Wiring loops
    To reduce the magnitude of transient overvoltages, the PV array wiring shall be laid in such a
    way that the area of conductive loops is minimum (e.g. by laying cables in parallel as shown
    in Figure 712.10)
  2. #12
    Page 36 clears up the confusion with regards to solar wires in PVC/metallic wireways.
    If you decide to install single insulated cable in PVC conduit, it must be installed in a separate conduit, however
    IF you install double insulated PV specific cable, it should be installed inside the same PVC or metallic conduit.
    In fact as you read the document, you will see that every precaution should be taken not to separate the conductors to prevent other issues.
    The positive and negative should be installed as close as practical at all times, even between the panels, jumping for the top to the bottom string with only one conductors is not advisable.
    Lets get the fact correct.
    There is a reason to keep the 2 DC wires close as possible(parallel), being DC, there is a magnetic field created around the wire if it is individual. Having both close to each other cancels this magnetic field.
    Understanding that the wire could be similar to a wire in a generator, it can induce voltages in any other wire running close. Now in most cases there is a a high DC current flowing, and high lights how strong these magnetic fields become, now imagine the same thought with respect to battery supplied cables pushing +100A.
  3. #13
    Mar 2022
    I have seen installations where the panel wiring goes along the top pos. to neg. around the outside, then down to the next string and along the bottom and back up to top, creating a nice big loop.
    Some installations, every second panel is flipped also creating anice big open loop.
    Then you get the one where the pos. is on the left and the neg. is on the right of the string.
    But hey people learning as they go, there is still a lot to learn and unfortunately the customer is going to sit with the problems.
  1. Split conduit for the solar wires
    Last Post: 24-Apr-24, 05:41 PM
  2. Fibre and network cables in electrical wireways
    Last Post: 10-Mar-24, 11:42 AM
  3. Double insulated wire
    Last Post: 12-Sep-22, 06:50 PM
  4. Oil filled paper insulated cable
    Last Post: 03-Mar-21, 11:36 AM
  5. Double tube Double headscratch
    Last Post: 14-Apr-11, 06:38 PM
