Results 1 to 5 of 5
Thread: Repair cable insulation with insulation tape
    May 2023
    KZN
    Am running 10mm house wire in trunking between mains and hybrid inverter. Just discovered a small tear (under 1cm) in my live wire insulation, earth is also damaged at that point - about 10cm of insulation.
    None of the conductors looks damaged - just the insulation.
    Have wrapped Nitto insulation around it - is this fine?
    Mar 2022
    I normall sleeve the damage insulation and if I cant fit sleeving, I wrap rubber tape (like you get in the joint kits) with a small cable tie or nitto tape.
    House wire in trunking...
    Mar 2022
    We wire up factories using house wire in P8000 and P9000 metal trunking. Every single factory I work in , the lights in the facotry are wired using P1000, some with 5 amp sockets, others with rows and rows of 5 ft fittings. Has something change that I am notaware of?
    Comment withdrawn
    (Had something else in mind...)
  1. Is using insulation tape on downlights compliant
    By GKen in forum Electrical Contracting Industry Forum
    Last Post: 27-Apr-23, 07:44 AM
  2. Roof Insulation
    By SCW in forum General Chat Forum
    Last Post: 02-Nov-22, 12:34 PM
  3. [Question] Insulation piercing connectors
    By kahoel117 in forum Electrical Contracting Industry Forum
    Last Post: 20-Jun-13, 11:45 AM
  4. Insulation resistance test
    Last Post: 04-Sep-12, 04:38 PM
