Results 1 to 5 of 5
Thread: auto switch from PV's to mains
    Jul 2023
    gauteng
    Good Day Forum – I’m interested in the topic about automated changeover switching on an inverter. The system installed is an 8.8kW Sunsynk with batteries for loadshedding and working well as designed. There is no plan to go off-grid, so mains supply needs to remain an integral part of the system.
    We added 16x 550W PV panels to the system and need to make them work for their money, eg power A/Cons, S/pool and HP as well as electric car charger in future (whenever this will be).
    For obvious reason those items have not been connected to the inverter/battery and are run from the mains supply (when available). Now with the PV installed we want to power those items from the PV’s, BUT still never from the battery.
    Only when PV’s are working during sun/day light conditions should they power the items, which means any auto switch system must be driven by those conditions as well.
    loch
    Quote Originally Posted by loch View Post
    loch
    If the Sunsynk is set up correctly and feeding back to CT with the CT situated at the point of supply then the excess PV will automatically feed your grid and anything on it - You may need to just move your usage of the loads to maximize the advantage of the sun through the use of timers
    Mar 2022
    Your installer can make the adjustments from their phone or plant list on a laptop.
    So long as you inverter has the latest firmware 6.0.2.4 and the remote access is ticked.
    Jan 2021
    Orania
    You may also want to check your general/auxiliary port as a possible source for connecting these devices. It can be programmed for this purpose.
    Jul 2023
    gauteng
    Thks for this
  1. In case of accidental leakge switch off the main switch
    Last Post: 14-May-23, 08:27 AM
  2. DB Monitoring, Mains sensing
    By LightsOn in forum Electrical Contracting Industry Forum
    Last Post: 22-Sep-22, 03:21 PM
  3. Mains Delay - Life After Loadshedding
    By daveob in forum General Business Forum
    Last Post: 19-Jun-15, 09:05 AM
  4. Mains voltage logger
    By duncan drennan in forum Technology Forum
    Last Post: 05-Feb-11, 03:33 PM
