Hi all
A friend has a Yamaha generator .
Internally it has no neutral to earth connection.
The Earth leakage will not trip when tested with EL tester .
There is also a polarity fault because one side of the winding is not connected to earth.
Where is the Protection.
One cannot connect neutral to earth externally.
He also has an inverter with the same setup.
What is the solution.
Some discussion would be appreciated.
Thank you
