Results 1 to 7 of 7
Thread: Help! 11 Pin contoler wiring
    Jan 2021
    Orania
    Help! 11 Pin controller wiring
    Good day gents
    It has been a while that I had worked with 11pin relays and contactors.
    I have to wire a 11 pin 3 phase over / under voltage monitor and the output must go to a 11 pin multi-function multi-range timer.
    From the 11 pin multi-function multi-range timer and the output goes to a 230V coil on a 3 phase contactor.
    The contactor is a MCE 240v 32A 3P+1NO
    The contactor is easy to do but the various input/output pins on the 11 pin base I don't remember them very well
    If anybody needs more info please contact me
    Both controllers are electrodev products. The timer is the T2m model and the 3 phase over / under voltage monitor is the V3E
    Jan 2021
    Orania
    Timer t2m
    Over / Under voltage V3E
Name:	over-under voltage 1.jpg
Name:	over-under voltage 2.jpg
    Photos of the products in question
    Oct 2018
    Gauteng
    Hi Thys,
    I see you posted a while back. Maybe you have it all sorted out. But just in case see attached wiring. I assume you want to energise the contactor once the power is back on and healthy for x seconds.
    Wiring Diagram:
    Wiring.pdf
    Thys LOW Elektries (06-Mar-23)
  5. #4
    Jan 2021
    Orania
    Thanks for the help.
    No I have not come right, small town little help.
    The idea is to protect fridges and computers that get damaged due to loadshedding and generator usage
    Greetings
  6. #5
    I do manufacture a product for industry which does this.
    3P5W Surge Protection.pdf
  7. #6
    Jan 2021
    Orania
    If I may ask? Do you know the freoguard? It is a 30Amp unit that protect an ice machine. Can you source or build something like that?
    This is where all the fun started. During loadshedding this unit burned out.
    They have an inverter system but the fault went pass the inverter or through it and not damaging the inverter.
    Somewhere during the changeover this happened, maybe the unit was on its way out in any case.
  8. #7
    Quote Originally Posted by Thys LOW Elektries View Post
    No Don't know it.
    Seems like a local supplier Cool Sense
  1. To COC or not bad wiring
    Last Post: 30-Oct-21, 07:18 PM
  2. Wiring Regulations
    By Darking in forum Electrical Contracting Industry Forum
    Last Post: 07-Sep-18, 01:35 PM
  3. DB wiring and CoC
    By AlexK in forum Electrical Contracting Industry Forum
    Last Post: 19-Feb-18, 02:46 PM
  4. Old wiring still legal?
    Last Post: 26-Sep-16, 08:44 AM
  5. Hobby wiring: Wiring requirements for a DCC railway layout
    By icrob in forum Electrical Contracting Industry Forum
    Last Post: 23-Jul-16, 05:29 PM
