Page 1 of 3 123 LastLast
Results 1 to 10 of 34
Thread: Grounding, earthing and lightning protection for solar panels
Hybrid View
    Mar 2022
    The first question, what is the purpose of the earth wire connected to the rails system? Lightning protection or to create a path to ground in case of leakage current.
    How do you determine if the installation requires lighting protection or just a leakage fault path?
    Then we should be asking, do we need to bond each panel in a daisy chain fashion.
    Do grounding lugs/plates mounted between the rail and the panel (stainless steel plate with points) create a suitable low resistance path?
    The earth spike, it seems to be another topic where people seem to feel that adding an earth spike is the right thing to do, but is it?
    Adding a metal structure to a roof, automatically creates an area in which is likely to attract lightning.
    The addition of the earth wire is to create a path from the metal structure to earth and reduce the damage which may be created by the charged air around the structure if there is no direct path to earth.
    Interestingly lightning in the majority of cases goes from earth to the charged clouds, as opposed to the other way round. What creates this is the fast buildup of charge in the air, the earth wire, reduces this charging time thereby reducing the damage to anything thats in the vicinity which could get damaged by the charge up process.
    Mar 2022
    The Anodised aluminum creates a high resistance, mounted to a wood structure, is it such a smart idea to add a whole lot of bare copper (low resistance) to a solar structure which will then attract lightning.
    Mounting it on a metal roof, well that is a whole different story, like any metal roof, add a electrical cable or power source, its becomes a job for people who specialise in lighting protection.
    From my experience with lightning, we always loose, no matter what protection we have installed. Be a borehole in a field miles away from civilisation or a house on a hill.
    Jun 2020
    Fourways
    This PV earthing/bonding what ever frustrates me a lot.
    We mount it to wooden beams through tiles, not extraneous to AC current.
    The positive and negative are not earthed so earthing is nothing. Albeit I believe some investors may do the earth and negative or positive bond.
    Also I spoke with dhen and there one clever degreed oak said anything 100 WP is then we it is considered.
    I mean lightning on a direct strike will destroy all.
    Induced voltages is different as SPDs can do a bit of that, so panels have surge protection which takes care of that so why we bonding/earthing panels ?
    Sure there is static that build up but the panels are class 2 ?? So then people say there are earthing holes and marks... Well maybe that is for the panels in the 100wp range and need LIGHTNING protection... Not surge or bonding.
    Bonding is to make metal work at Sam's potential... There is F all DC potential to be made or even AC on panels...
    At the moment it is a lot of doing what others do as there is ZERO guidance other than what we can take from out 10142-1 and lighting standards.
    The problem is that wood, glass, and any item that is not a conductor, becomes a dielectric to any 2 pieces of conducting material. In this case, between the aluminium frame, and the silicon PV cell, which in turn is connected to your electrical system via the inverter. Now a dielectric material stores a charge, or can be charged if left alone. So the idea of earthing the frame, is to reduce the potential difference between the PV solar Cell connected to the electrical system and the frame. Should there be a lightning strike, high voltage will flow through the dielectric and the metal parts, causing electrical failure to electronic components. Earthing the frame, ensures that the potential voltage between the metal parts will be small enough to reduce the risk of destroying the electronic components during a lightning strike.
    Mar 2022
    I think this is the confusion, people think they are earthing the panels with a 6 mm wire for lightning protection.
    Well it will work at least once
    Mar 2022
    I doubt a solar panel will survive a lightning strike if it is hit by lightning, I am yet to see anything survive a lightning strike no matter what measures when have taken to prevent it.
  9. #9
    Its all about rerouting the path of discharge away from the house.
  10. #10
    Mar 2022
    Lightning kills animals around the mobile towers (it use to) , some people are installing earth spikes next to their house and connecting the solar panels to that same earth spike.
  1. Solar power panels
    By reggy in forum Electrical Contracting Industry Forum
    Last Post: 28-Feb-23, 10:25 PM
  2. Installing solar panels
    Last Post: 07-Jan-23, 10:52 PM
  3. Lightning 6.7.7 and surge protection 6.7.6
    Last Post: 13-Sep-22, 05:40 PM
  4. Lightning and surge protection insurance
    Last Post: 25-Nov-21, 03:34 PM
  5. Lightning protection vs surge protection
    Last Post: 28-Feb-20, 08:02 AM
