Item: 12V Alarm / Gate Lithium Battery Upgrade (12v 7Ah SLA Alternative)
Direct replacement for a 12V 7Ah lead acid battery. Lithium Iron Phosphate LiFePO4 battery with BMS.
12v 7Ah sealed lead-acid (SLA) batteries are typically installed in small electronics that require backup power, like alarm systems and gate motors, but they are not ideal for regularly handling high current, and being discharged often or discharged too low. Thus when they are frequently drained (like during load shedding), they are easily damaged, and you will find that you need to replace them quite often.
This lithium iron phosphate battery on the other hand has a high cycle rate (2000 cycles, versus 200 to 400 cycles of an SLA battery), it can handle higher current, and the internal battery management system protects the battery from overcharging or discharging too low.
Link: https://loadshedbuddy.co.za/product/...a-alternative/
