Results 1 to 2 of 2
Thread: Do I have to issue a COC if I install 1 socket outlet
    Mar 2022
    I am sure this has been discussed before.
    If I chase the wall and install 1 socket outlet back to back with and existing socket outlet, do I have to issue a COC. We all know the answer is yes you do.
    The way I see it, you would issue a supplementary COC for the socket you install and attach it to the original COC.
    If it was that simple everyone would be happy and we could be sitting down enjoying a hot cuppa coffee, with the snow in the background.
    The catch, what if the customer cannot produce a COC for the socket outlet already installed ?
    The way I would handle this kind of situation, I would carry out the tests required, fill out a supplementary COC and hang on to it until I get the original.
    If I notice any visible code violations, I will document them and take photos then attach them to the supplementary COC.
    I would offer to carry out a full inspection report and submit a quote if an original cannot be produced.
    If the customer insists that I have to produce a COC for the 1 socket outlet, I would fill out as much detail on the supplementary as possible to CYA and put a line through all the open spaces.
    Mar 2022
    Little Falls, Roodepoort
    Agree fully - you can only certify what you have personally inspected and tested
  1. 6 Amp socket outlet and plugtop.
    Last Post: 20-Aug-22, 03:56 PM
  2. Replacing a metal socket outlet with a plastic socket outlet
    Last Post: 18-Jun-22, 04:17 PM
  3. Socket outlet above hob
    Last Post: 14-Nov-18, 02:57 PM
  4. Socket Outlet Confusion
    By BlueArc in forum Electrical Contracting Industry Forum
    Last Post: 05-Nov-14, 11:57 AM
  5. Socket outlet in bathroom
    By mlpotgieter in forum Electrical Contracting Industry Forum
    Last Post: 23-Oct-11, 12:10 AM
