Results 1 to 4 of 4
Thread: Isolation procedure for solar/inverter/batteries
    Mar 2022
    It was just a matter of time for something to go wrong.
    This is the second time I have had a call from customers, frantically trying to switch off a system. The first time was an installation where batteries started boiling and no isolation procedure, in fact not switch disconnector.
    Again 2 day ago another fault on a system and no isolation procedure.
    What is the problem, the installer will spend 2 hours running through with the owner telling him about his system and where to switch off, the owner is out of town on business and suddenly there is problem, a loud high pitched sound coming from the unit, what now.
    I can tell you what now, panic and run.
    While the pro's design the regs for solar, they should include a clause which includes documentation with cables routes and isolation points required to safely isolate the system.
    IF the owner who may remember how the system works for the first 3 days or 3 weeks, is not home and there is a problem, or if the installer who might not be around in 6 months time cannot reached. If the fireman or another electrician is sent to the site, there must be a site document wit hall the relevant information about the system.
    I know the first response would be to run, however eventually someone will need to shut it down.
    Dont be that person who causes a family home to burn to the ground because you an idiot who is too irresponsible to create a simple diagram and leave it for other to fix your mess.
    Yep to save a couple of hundred Rand, on a R100K plus is ludicrous.
    In all my design work of any system, the first item on my list is "Safety",
    the second is - how will the customer make the system safe in the case of a catastrophic failure, with out requiring an engineering degree, and if this will be a problem, then an automated shut down of the system becomes part of the design. This could be a hidden 'Fuse' , non re-settable circuit breaker or a electrically controlled fail to make safe contacts.
    But again I have told been that my equipment is always expensive.
    My reply to that, is the day that you complain the price is cheap, then I know that I have made an error in my design/calculations
    Mar 2022
    Anyone have a PDF for the safe isolation of solar installations and a startup and shut down procedure?
    I have started putting one together, just need to verify the content.
    Mar 2022
    Any tips on what documentation you should leave at the inverter?
    Sketches:
    1/Equipment layout and isolator location.
    2/Electrical circuit diagram, non essential and essential.
    How to switch on/off the system:
    1/ Startup and shutdown procedure.
    2/ What to switch off in case of emergency.
    3/ What not to switch off under normal operation.
  1. Solar, inverter and batteries, why
    Last Post: 19-Jul-23, 08:43 AM
  2. [Question] Using Hybrid inverter without batteries.
    By CGelectrical in forum Electrical Contracting Industry Forum
    Last Post: 11-Mar-22, 08:15 AM
  3. Solar inverter installation investigations
    Last Post: 17-Feb-21, 12:19 PM
  4. generator inverter or solar
    By ians in forum Energy and Resource Conservation Forum
    Last Post: 19-Sep-20, 09:09 AM
  5. Solar inverter
    By Rifrug in forum Electrical Contracting Industry Forum
    Last Post: 20-Dec-19, 08:15 AM
