Results 1 to 3 of 3
Thread: Inverter fault levels
    Mar 2022
    This is an interesting question, what is the fault level at the inverter when it switches over to battery backup, if you have one, 2 or 10 batteries connected.
    How do you work out the fault level when carrying out the inspection report for the COC?
    Lets say a you are using 5.2 kwh (48 VDC) batteries, in parallel.
    I am interested to see some of the calculations done by electricians who issue COC for solar installations.
    Mar 2019
    East london
    Where on the test report would one enter those particulars ?
    Your Fault level on the AC output will be the max peak output of the inverter which is anywhere between 1,5 to 2 times the rating of the inverter .
    The fault level is low.
    The DC fault level internally on the inverter is a different story - With Lithium the BMS will restrict the fault current.
    With Gel it takes a bit of calculation but is generally around 12 times the Amp hr rating
  1. A new fault never experienced before.
    Last Post: 20-Nov-23, 02:21 PM
  2. [Article] The 7 levels of internet marketers..Where are You?
    By G Robin in forum General Business Forum
    Last Post: 19-Sep-10, 10:07 AM
  3. It's not my fault!
    By Dave A in forum South African Politics Forum
    Last Post: 09-Dec-08, 01:43 PM
  4. Increasing levels of legislation and regulation
    By Yvonne in forum South African Politics Forum
    Last Post: 30-Jul-07, 10:02 AM
