Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Which 48 volt lithium battery is the best
Hybrid View
    Mar 2022
    Could the C rating be reduced to protect "seconds" (not off the production line) batteries?
    The BMS in the batteries, only provide 2 functions as far as I know.
    1 - If the battery voltage drops below a predefined value, it disconnects the battery from the load. Gets enabled when the charger is enabled
    2 - In the case of a short circuit, then the BMS will disconnect the battery from the load. I am not sure here but i think it is again enabled when the charger is enabled.
    Mar 2022
    Mar 2022
    I see it is official, you get a 10 year warranty for your Sunsynk setup if you use the Sunsynk battery with the Sunsynk inverter, why would you you sacrifice a 10 year warranty and use any other battery?
    Jan 2019
    Durbanville
    I got a 10 year guarantee for a DYE battery connected to a luxpower inverter, very happy with it.
    New Member HGTesla's Avatar
    Jul 2023
    China
    Choosing the appropriate 48-volt lithium battery type depends on specific requirements and application scenarios. Ensuring compatibility with the inverter or solar power system and meeting specific needs is crucial.
    Mar 2022
    When selecting the battery for your system, how would the C rating affect the design?
    From the little experience I have installing inverters, you never want your system to be pulling 100% @100 amps if you are using a 100 amp/hr battery, especially if you are using the system as a backup (UPS type). You would need a pile of batteries if that is the case, then 0.5 or 1 C wouldnt be a a priority.
    An example: If you are using it for critical/essential loads, which generally the case in SA, the system should not not be fully loaded at any point, you want the system to support your essential loads at any point of the day or night with at least 6 hours of support, preferably longer, but they budget would determine the support period. The longest life cycle would be the better option, not the higher C rating.
    Another example would be a small workshop. A battery which can handle the full discharge capacity for short bursts would be a good option, because you might be running small machine with motors which start up. You are looking for a system to keep the workshop flow.
    It all seems to keep going back to one thing, design for the application. The solar and inverter audits fails seem to point at bad design. Understanding and designing the system around the customers application seems to be the missing link.
    Agreed, full C in my opinion should be reserved for instantaneous requirement of any load for a short period of time.
    I usually like to cater for at least 6 hours of load on my battery pack, preferably 10 hours.
    At 10 ours it ensures longer battery life due to the reduced period of charge time at a high rate to bring the capacity up to cater for the constant load shedding experienced in recent days.
  1. Selecting a solar lithium battery
    Last Post: 11-Sep-23, 10:28 AM
  2. Charging lithium batteries
    Last Post: 23-May-21, 06:15 PM
  3. Swopping out lead acid batteries with lithium
    Last Post: 11-May-21, 08:07 AM
  4. 12 volt lighting
    Last Post: 13-Oct-20, 12:46 PM
  5. energy saving 12 volt or 230 volt downlighters?
    Last Post: 14-May-12, 08:49 PM
