Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Which 48 volt lithium battery is the best
    Mar 2022
    This seems to be a more difficult task than I could have imagined.
    What do you consider when choosing a backup battery for your inverter or solar system?
    1/ The type of cells used?
    2/ The type of BMS used?
    3/ Temperature monitoring?
    3/ How the battery temperature is managed during charge and discharge cycles?
    4/ Compatibility with the inverter you choose.
    5/ Charge and discharge rate, this seems to be trick question, normal, max or advisable
    6/ Life cycles? how many time it can be charged and discharged
    7/ Designed life expectancy, 10 or 20 years?
    8/ Firmware and software compatibility with inverters?
    9/ Type of BMS of communication?
    10/ parallel connections, how many etc?
    Those days of talking about a the thickness of the lead cells or the battery case base and battery amperage only is a thing of the past.
    Batteries have become complex little power houses.
    what I thought would be a simple question, who makes the best bang for your buck with all the frills.
    Which battery is the best and why? Can anyone supply credible data comparing lithium batteries with lithium batteries.
    I bought a blue nova battery and cut it up to see what it looks like inside. It was assembled better than I expected.
    Maybe I should buy each battery sold in SA and strip it, check things like the QR on the cells to verify the information on the data sheet, do capacity checks and show everyone how they are built.
    Mar 2022
    I do realise my warranty would no longer be valid I am not sure that there would be any legal implications, I see guys doing it on youtube all the time.
    Mar 2022
    Lets start with the cells.
    BYD prismatic cells seem to be the preferred ones. They advertise -
    The cell has a larger surface area than regular prismatic cells, allowing for better heat dissipation. The cells also allow for slow heat release, lower heat generation, high starting temperature for exothermic reactions, and do not release oxygen during thermal runaway.
    It looks like I will be spending the next few weeks doing research into lithium batteries.
    Mar 2022
    I still cant find someone to answer what I thought would be a very simple question, how to determine the C rating of a battery in manner which can be used to compare information published on data sheets.
    BU-402: What Is C-rate?
    The C is usually provided by the battery manufacturer.
    Mar 2022
    The protective device controls the C rate?
    If one battery has the same capacity and cell type, then the manufacturer would control the charge and discharge rate protection?
    Buying a 0.5C or 1C battery cycle life would perform the same and the life cycle would be the same if both charged and discharged at the same rate at the same temperature?
    The 0.5C would have internal protection to prevent the battery being "hammered" with high charge and discharge rates, hence a higher life cycle advertised?
    A 1C battery protection would be toned down, allowing the battery to be "hammered" thus reducing the life cycle?
    All just question it seems impossible to find out from any of the suppliers. I have tried contacting numerous outlets and manufacturers, either "we are experiencing high call volumes please be patient" or I have left messages and nobody returns my calls. It seems the call centre are manned by operators with a spec sheet with just enough info to answer most common questions, most of us know already.
    I will just keep scratching until I understand.
    "While lead- and nickel-based batteries can be discharged at a high rate, the protection circuit prevents the Li-ion Energy Cell from discharging above 1C. The Power Cell with nickel, manganese and/or phosphate active material can tolerate discharge rates of up to 10C and the current threshold is set higher accordingly."
    Mar 2022
    I think its time to buy a few different batteries and open them, check if they have QR codes on the cells, then see how they are assembled.
    I have already popped open a blue nova battery ( yip warranty out the window), I am going to have to cut the plastic off, then get a blow torch to remove the resin.
    Any legal experts know if it will be ok for me to post pics of the battery in pieces? I see the youtubers do it all the time, so I am assuming there will be no issues?
    Mar 2022
    Could the C rating be reduced to protect "seconds" (not off the production line) batteries?
  9. #9
    Mar 2022
  10. #10
    Mar 2022
    I see it is official, you get a 10 year warranty for your Sunsynk setup if you use the Sunsynk battery with the Sunsynk inverter, why would you you sacrifice a 10 year warranty and use any other battery?
  1. Selecting a solar lithium battery
    Last Post: 11-Sep-23, 10:28 AM
  2. Charging lithium batteries
    Last Post: 23-May-21, 06:15 PM
  3. Swopping out lead acid batteries with lithium
    Last Post: 11-May-21, 08:07 AM
  4. 12 volt lighting
    Last Post: 13-Oct-20, 12:46 PM
  5. energy saving 12 volt or 230 volt downlighters?
    Last Post: 14-May-12, 08:49 PM
