Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Selecting a solar lithium battery
Hybrid View
    Mar 2022
    It seems once again, no apples with apples comparisons, only apples with oranges and pears with grapes.
    What are the key factor to consider.
    The battery capacity in amp/hr and KWh
    Cycle life @ the C rating.
    The normal and max charge/discharge current.
    The type of cells being used in the battery.
    The communication with the inverter.
    How many you can connect in parallel.
    Working temperature.
    The warranty.
    Very very important, the support and availability.
    Mar 2022
    The C rating of the battery, which is better?
    Hubble
    New Li-ion Prismatic Cells
    3000 Cycles @ 100% DOD, Above 6000 cycles @ 50% DOD
    Or
    Sunsynk
    LiFePO4,Lithium Iron Phosphate
    6000 Cycles @ 80% DOD / 25°C / 0.5C, 60% EOL
    So if you increase the Sunsynk to 1C then it would only offer 300 cycles, it would be the same specs?
    I am trying to understand which would be a better buy, they are both the same price, Hubble a little more expensive.
    If it were the support, the company I am dealing with for the Sunsynk would be my choice.
    It seems they both have the same cells, the communication is better between the Sunsynk inverter and the Sunsynk battery and I hear if I use the Sunsynk battery with the Sunsynk inverter there could be a better warranty period on both products.
    DO you have any other suggestions or comments with regards to selecting a battery for the Sunsynk inverter.
    Some say the Deye and Sunsynk are the same inverter out the same factory, unfortunately I will only be able to comment on that once I have the inverter and battery setup on my work bench.
    Mar 2022
    I hear chatter about, lithium batteries being sold which are not off the production line, how could you verify if the cells in your battery pack are off the production line or if they repurposed?
    A QR code on the cells maybe, considering a seal would be fitted to all batteries, how would you verify the origin of the cells used in your battery?
    This could become a huge problem as older batteries are decommissioned.
    Mar 2022
    You need to read the warranty forms, the features and all that sales jargon is just that, sales jargon
    Warranty Exclusions & Terms and Conditions:
    The battery has a 15 year intended design life, however the battery cells should achieve at least 5 years’ service life or deliver at least 3000 charge, discharge cycles as counted by the BMS, which ever event is achieved first.
    however a standard 3 year warranty is provided for the BMS
    9. If placed in storage then the ambient temperature should be no higher than 25 degrees Celsius.
    24. Any damage to the battery caused by peripheral electrical equipment.
    The integrated BMS module is designed to last over 15 years, however a standard 3 year warranty is provided for the BMS and all related probes and sensors.
    The operating temperature for the battery is designed to be 0 to 55 degrees Celsius, however it is recommended to keep the battery below 25 degrees Celsius to maximise the design life and life cycle of the battery. The cycle life is negatively affected by temperatures above 25 degrees and cannot be guaranteed if the battery is operated in temperatures exceeding 25 degrees Celsius.
    Mar 2022
    To give you an idea, I downloaded the data for a Sunsynk 5.3 kwh battery, the battery was installed mid November 2022. It indicates that it has cycled 43 times. Lets say 50 cycles per 6 months, that would mean 100 cycles per year.
    A quick calculation 6000 cycles/ 100 per year = 60 years.
    I have 8 (left) Makita 18 VDC batteries, used on site literally everyday. The batteries are old (cant say the exact date of purchase) years. Had then tested, no faults, SOH 100% 80 % charged at the time of test. Cycles ranging between 450 and 500, which indicated that we are alternating the batteires often.
    2 other batteries purchased at around the same time, used with a makita tool which is not star rated and ran flat, both indicated faulty when I attempted to charge them. I stripped then and recovered the cells, still being used for site torches. I should have done the bridge charge, because I beleive it was a BMS cutout issue (you live and learn). I think the manager at Makita was even surprised at how long the batteires have lasted.
    I dont understand why the HIlti 36 VDC batteries dont last, I have both 22 VDC and 36 VDC Hilti batteires, the 22 VDC we used everday, the 36 VDC batteries have very few cycles yet they no longer charge, I took them to the hilti store, they indicated they dont ahve a tester for the batteires. Dont try strip a Hilti battery. I am going to rather take it as is, to Hilti and let them dispose of them.
    Mar 2022
    The next question -
    Lets try get an apples for apples comparison @ 25degreesC :
    If both batteries had 3000 cycles @ 100 % DOD, what would be the C rating of the Sunsynk battery?
    IF both batteries had 6000 cycles A 80% DOD what would be the C rating of the Hubble battery?
    If both batteries had 6000 cycles @ 100% DOD what would the EOL % value be?
    What makes the one battery better than the other, taking into consideration that we are going to be installing Sunsynk inverters for our customers.
    The shape of the cells, hubble indicates the use of prismatic cells? I would need to find out the shape of the Sunsynk cell, I would think by now they are also using prismatic cells.
    The capacity of the individual cells? Could the Hubble battery be using a higher amp/hr cell or more cells to give it a 1C rating and +/- 16 year design life?
    Would that indicate that the Sunsynk has a 30 year design life @ 6000 cycles?
    The communication between the inverter and the battery and the software for the monitoring?
    The make of the cells, Hubble indicate they using BYD ? I somewhere that Sunsynk are using a rebranded BYD battery, I would need to verify this statement.
    Just so many questions. I am glad I am at that point where people cant baffle me with all the bullshyte I hear or read. So many experts in this field, trying to find that person who has a little more knowledge than the general ramble, can prove to be a challenge.
    Very difficult to compare batteries, as each supplier cherry picks the specifications they wish to hand to customers.
    The 'C' rating refers to the charge value/capacity for reliable battery life.
    Charging Lithium at 1C, will require careful monitoring of cell temperature, and reducing current(C) as the temperature rises.
    Un-monitored battery temperature would recommend a below 0.5C
    Mar 2022
    Its seems the challenge to get credible information out of battery manufacturers and suppliers is a lot more difficult than I thought.
    You get to listen to a lot of "please hold your call is important to us" or "please hold why I redirect your call" or some tune while the technical person you are speaking to has to find a technical person who can relay the information to the technical person who has very basic technical knowledge.
    Now I know why we are sitting with really badly designed R150 000.00 solar systems
  9. #9
    Mar 2022
    3.1 In respect of the Lithium Iron Phosphate (LiFePO4) cells (hereinafter “the Cells”), the duration ofthe warranty shall be 10 years or five thousand (5000) cycles (whichever comes first),commencing on the date of sale.
    3.2 For purposes of paragraph
    3.1 a single cycle for the NG (New Generation) range is defined as adischarge to maximum 80% depth of discharge of the battery’s capacity at >C/10 (capacity at a10 hour discharge rate or more) followed by a recharge to 100% state-of-charge, and a singlecycle for the HC (High Current) range is defined as a discharge to maximum 80% depth ofdischarge of the battery’s capacity at >C/2 (capacity at a 2 hour discharge rate or more) followedby a recharge to 100% state-of-charge at >C/2 (capacity at a 2 hour recharge rate or more).
  10. #10
    Mar 2022
    Been doing more research into batteries today.
    I still cannot find what makes one 5 kwh lithium battery better than another brand.
    It seems that all batteries are capable of 1C, it just cuts the life span in half.
    So if a battery offers 1C capabilities, you will notice it only has a 3000 cycle life span.
    So the battery offering 0.5C will have a 6000 cycle life span.
    Prismatic cells are not a selling point, like BYD cells used by most reputable brands to build their batteries using prismatic cells.
    I am at the point were I believe it boils down to the compatibility of the battery to the inverter. Using a Sunsynk battery with a Sunsynk inverter just makes more sense. I am sure the Sunsynk is rebranded battery spec'd to work with the inverter.
    There is a R2000 difference and something else to consider is the delivery cost and courier fees if the battery fails. It starts adding up. Where you source these products could make or break the sale.
  1. Battery selection for your inverter solar installation
    Last Post: 05-Jun-22, 08:46 AM
  2. Charging battery with solar charger and inverter charger
    By Tang in forum Electrical Contracting Industry Forum
    Last Post: 06-May-22, 08:25 AM
  3. Charging lithium batteries
    Last Post: 23-May-21, 06:15 PM
  4. Swopping out lead acid batteries with lithium
    Last Post: 11-May-21, 08:07 AM
  5. Replies: 5
    Last Post: 06-Nov-19, 04:48 PM
