Hi all
Which GU10 LED lamps does everyone use. Which work better?
I have been using Shuttle dimmers with Osram Performance dimmable lamps but sometimes they "pulse" rather than being steady when at a certain level.
Any other recomendations?
Hi all
We used to install the same. Replaced a few shuttles as well but all seemed alright. Admittedly not done many.
I will soon be doing 39 synerji bulbs and then a mixture of the synerji dimmable module ( looks identical to shuttle) and then another new brand of dimmer module called "bekkel " only 115VA, not sure of PF, but doing max 6 bulbs.
Will report on them as best I can so we can have some tracked research as well.
Yesterday I came across some led downlights that flickered in the evening, around 7pm, so the customer tells me.
Only the lights on Dimmers flicker, all at the same time, around 7pm.
When dimmed the lights do not dim more than about 20 percent
They are powered by a Shuttle dimmer, SDIM-T-LED-500W.
The lights are 220v Pioled Gu10 4.5w CW DIM, there are 8 on that particular circuit. All the lights in the house are the same, downlights, but not all are on Dimmers.
To be honest I was not sure as this is not my area of expertise.
Customer has decided to remove the Dimmers.
Any ideas?
Add one single 20W incandescent light to the circuit.
Led's are current sensitive it could be caused by inrush currents when you switch on high wattage devices especially stoves.
This might help with your problem
led-dimmer list-bulbs and spots.pdf
