Results 1 to 2 of 2
Thread: Pressure pump plus pressure tank
    Jan 2022
    Kei Mouth
    Question Pressure pump plus pressure tank
    I have a 0.75kw pressure pump connected to 4x5kl JoJo tanks. It has a pump controller fitted.
    One of these: https://www.takealot.com/dab-jetcom-...p/PLID54546422
    And one of these: https://www.takealot.com/automatic-d...c=ds&gclsrc=ds
    It all works well but I would like to have some backup pressure for when there are power outages. I got myself a 60l Varem pressure tank (with bladder and flange) - similar to this:
    https://www.stepbuildingsupplies.co....ssure-tank-60l
    Can I just connect that in line with the existing pump and controller?
    I believe there is a sort of a T-piece that connects to the tank with flexi hoses.
    I spoke with a plumber who said you usually have the pump controller or pressure tank, but not both... but I was thinking, I like the electronic pump controller- no need for a float switch in my tanks, but I'd like the benefit of the reserve pressure from the pressure tank so that when there's an eskom outage, I can still use my drinking water tap and fill up a 5l or so container. Also, I don't want the pump to kick in every time I open a tap.
    Should I remove the electronic pump controller if I'm fitting the pressure tank? What else does the pressure tank need to operate?
    Thanks in advance!
    I would say the plumber is correct in one or the other but there are advantages of having both
    The pressure tank would need a pressure switch to operate the pump if only the tank is used
    I would leave the pressure controller that you presently have on the pump which will basically do the same job as if you put a pressure switch on the tank.
    The advantage of the controller is the run dry function as you mentioned.
    It will give you a bit of pressure for a bit if there is a power failure but not much, and it should slow down the cycling of the pump on low volume usage .
    The pressure controller has a non return value so you will not need to install an extra non return value on the tank or as shown in the tank installation drawings
  1. Problem with industrial geyser tank contactor
    By BlueArc in forum Electrical Contracting Industry Forum
    Last Post: 19-Dec-13, 08:51 PM
  2. Pump with Pressure Tank ???
    By tec0 in forum Electrical Contracting Industry Forum
    Last Post: 03-Nov-13, 10:52 AM
  3. Pressure on productivity
    By Dave A in forum Entrepreneurship and Business Management Forum
    Last Post: 09-Sep-10, 01:29 PM
