Hello
Having issues with a D5 gate motor at a client.
When it closes it does not close all the way, about 100mm left to go then it says "motor stall" and then opens again. It repeated this until someone helps to push the last bit.
It is intermittent and only does it sometimes.
I re-did the gate limits and seems to work a few times then it acts up again for a bit.
Anyone know what to do or what else to check?
What i have checked:
-There are no items blocking it.
- it does not get to the wall on the other side to obstruct against. Originally appeared it did then I bent the hook away but to no avail.
- the
- the collision forces are on max (was set already like that)
The gate opens slowish then speeds up then slows down then does a very slow like final push to finish its process and say "closed " on the screen.
My feelings now is that the gate might be too heavy or the rack is too much on the pinion and the friction is creating false motor stalls when near the end of its run.
I do not do much gate motors and normally a limit setup sorts it.
Any guidence would be highly appreciated.
