Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Common code violations
  1. #11
    planet earth
    b) shall use conductors that are rated at not less than 16 A, and
    I have this situation at the moment ... a customer wanted me to move a light in the garden and fit a weather proof socket outlet for some strip lights.
    The DB has a mixed circuit label ... with a 10 amp circuit breaker feeding the light and socket outlet ... with a label on the weather proof socket "for lights only" ... I did consider using a dedicated type socket outlet.
    To lift all the paving to replace the cable with a 2.5 mm cable ... was not in the budget.
  2. #12
    You could use a 4x2 , 5 amp socket outlet in a weatherproof box
  3. #13
    planet earth
    5 amp cord cant be longer than 3 m ?
    but I suppose the cord between the strip lights and the socket outlet is only 1.5 m ... the other 5 m of the actual light wouldnt be included.
    As I think about it ... I should have installed a junction box ... fitted a wireless switch (like a shelly or sonoff) in side the weatherproof box and just connected both the pole light and strip light to the wireless switch.
    The customer has already complained that he tried to use the weed eater but it tripped the 10 amp breaker.
  4. #14
    planet earth
    I have an interesting COC ... you can see the inspector has been to site and has offered to return to fix a few item not completed before the sale.
    I walked around the site to see if it warrants a service sheet ... at first I didnt think so ... but as we dig deeper I am starting to wonder about the lights.
    The ceiling is high ... and I hear the inspector will be back to replace one or 2 ... I noticed a couple old brass holder fittings and no earth wire ... then I noticed round boxes outside for the security lights ... all the end boxes facing up and I could bet my scrap box that the glands are not the flat type which will result in a bad IP rating ... then I ask myself ... are the round boxes UV rated for outdoors and are the boxes filled with a compound to improve the IP rating.
    I didnt have ladder with me so I havent opened the trap door yet.
    So now I ask myself ... who is going to pay for my time to start scratching.
    We have another the customer who is complaining about what seems to be a few code violations ... my response to the customer was to get his electrician to open a service sheet and log the time and at the same time create a list of the violations with reference to the code.
    It seems it is too easy for people to just complain about COC's without actually understanding how it works and what is covered ... I hear a lot of complaint about light fittings not working ... the wiring to the fitting is correct ... a bulb or 2 might be blown ... this is where public awareness is lacking.
  1. Plugs having something in common.
    Last Post: 26-Sep-21, 05:52 AM
  2. Blank Code and Group code does not exist
    By Helizel in forum Accounting Forum
    Last Post: 19-Jun-20, 10:56 PM
  3. Not so common Quotes
    By adrianh in forum General Chat Forum
    Last Post: 03-Feb-20, 08:42 AM
  4. Replies: 0
    Last Post: 18-Aug-17, 10:40 AM
  5. Replies: 3
    Last Post: 09-Jan-15, 08:33 AM
