Results 1 to 5 of 5
Thread: Fees for replacement of mains breaker?
    Aug 2019
    Mossel Bay
    Good day sparkies.
    Could I ask what the general fee would be to replace a mains breaker in a DB including the call-out?
    Also, i assume it will require a COC on replacement? Even if it's the exact same breaker?
    TIA
    Sent from my SM-A515F using Tapatalk
    Probably 1 hour labour plus materials. No, a CoC shouldn't be necessary.
    Why does your main breaker need replacing?
    planet earth
    It should cost between R800 - R1000 including labour and material ... as Andy noted ... no COC required.
    If it is a straight forward remove and replace ...
    However ... not always that simple ... from my experience ... because it might be an old Heineman type with the old clip system ... replacing it with a Heinemann breaker is going to break the bank ... you could replace it with a NUR (cost around R180) a adaptor plate will still be required ... or you could use a din rail mount breaker much cheaper ... but a little more work required to fit ... if it is an old heneman type main switch ... the reis a chance it is narrower than the new ones ... which could involves cutting the cover to fit or moving the breaker over slightly.
    Take a picture and post it.
    Quote Originally Posted by LuX10N View Post
    Good day sparkies.
    TIA
    Without knowing the size and extent of work , I don't think we can answer - Is it a 80Amp single phase system or a 1250Amp CB with busbar arrangement that may now need busbars to be changed and flexible cable used .
    Will you be able to carry out the work in normal time or afterhours
    The distance that will need to be travelled and time lost travelling.
    Will you need to get the local authority in to switch off the incoming supply
    Sep 2021
    cape town
    If Samite(CBI) and is a simple job you should not pay a ball park figure of over R1500 for everything(labour and materials).
  1. [Question] Mains feed to 80 year old apartment block - sufficient to install 82 geysers?
    By Parkhere in forum Electrical Contracting Industry Forum
    Last Post: 11-Oct-17, 07:13 PM
  2. Domestic Earth Fault loop at mains position - convert to TNC-S?
    Last Post: 09-Jul-16, 11:49 AM
  3. Mains Delay - Life After Loadshedding
    By daveob in forum General Business Forum
    Last Post: 19-Jun-15, 09:05 AM
  4. [Question] Late Payments: Interest fees, Handling fees, Collection Costs, Service fees
    By ACEsterhuizen in forum Electrical Contracting Industry Forum
    Last Post: 28-Feb-15, 02:38 AM
  5. Mains voltage logger
    By duncan drennan in forum Technology Forum
    Last Post: 05-Feb-11, 03:33 PM
