Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Heated towel rails
    Jan 2021
    Heated towel rails
    Morning guys.
    I must install several heated towel rails in a few bathrooms.
    1 is RIGHT NEXT TO A BATH.
    How legal are these things?
    The thought that you can be in the bath and touch the rail concerns me.
    Will put on ELU.
    What else?
    Any thoughts
    There's very specific rules around electrical installations in bathrooms, read the regulations regarding electrical zones around baths.
    Jan 2021
    If I do not include on coc and state in an additional page that it is not included would that be safe for me?
    Or is that bad practice.. Or acceptable?
    If you exclude parts of the electrical installation than the certificate is not valid.
    If you look at the regs around the zoning of a bath , yes you can fit a heater towel rail above the bath in zone 1 subject to the conditions listed in Table 7.1
    We were once asked if you could fit a heater towel rail in a shower and when we looked at dimensions , we could legally fit it .Was a bit bigger than a normal shower.
    Jan 2021
    OK thanks
    Will whip out the regs book tonight and have a squizz thanks
    planet earth
    I am busy with 2 heated towel rail installations ... they can be fitted next to the bath ... you just need to make sure you read the conditions as per the regs.
    Jan 2021
    Checked my regs book.
    Will fall into zone 2.
    Onky problem is where do I put the isolator as it's a fixed appliance.
    No ceiling in this particular bathroom.
    An isolator mounted on tiles will look ugly.
    planet earth
    I have used a 6 way 4x4 grid plate ... 3 x 20 amp D/P isolators (2 x heated towel rails and 1 x Xfan) on the bottom row and 3 light switches on the top row.
    You can use a 4x 2 ... but it beomes a little tight with all the wires in and out.
    The rules state with 1.5 m ... but once again ... a little common sense tells me its better to have the isolators on the light switch than in the bathroom ... a note on the COC ... justifying my logic.
  9. #9
    I was involved with having to answer a query over heated towel rails which often crops up .
    I am attaching a document below which will assist with future queries
    Attached Files Attached Files
    Isetech (14-Mar-23)
  11. #10
    Mar 2022
    I dont know that I would be happy with someone installing a heated towel rail in my shower cubicle ;(
  1. Heated towel rail/instant water heater in a bathroom
    Last Post: 13-Apr-21, 10:08 AM
  2. Shaver plugs and towel rails
    By LuX10N in forum Electrical Contracting Industry Forum
    Last Post: 14-Sep-19, 08:25 AM
