Results 1 to 4 of 4
Thread: Swopping out lead acid batteries with lithium
    planet earth
    The question is ... can you just take your 7 amp/hr battery and repalce it with a blue nova 8 amp/hr ?
    That the challenge right now ... trying to find out if it is that simple.
    I dont think so ... unless you can adjust the charge perimeters on your alarm/gate or garage door.
    Is it worth replacing a R150 battery with a R1000 battery?
    According to Blue Nova data sheet, it is supposed to be a "Drop-in lead acid replacement".
    What I do not understand is this
    Charge/Discharge
    Discharge Voltage (min.) 11.6 V
    then under
    PROTECTION
    Under-voltage Cut-out 10.0 V
    planet earth
    YOu have to open a ticket with Blue nova to get a response ... you cant just contact them and request information about there product.
    I am busy in correspndence with them at the moment trying to get information about this so called drop in replacement battery.
    From what I understand ...there has not been workshop tests carried ... no load shedding impact testing.
    There is a data sheet for the drop in batteries.
    From the little knowledge I have it is a little more complicated than just drop in a lithium battery in place of a lead acid.
    Alalrms/gates and grage doors have chargers designed to lead acid specs ... lithium batteires dont have the same charge/discharge properties as lead acid.
    When you start looking into inverters and solar power ... there have to be specific setting for lithium batteries.
    Vitron for example have setting in their chargers for lithium and flooded lead acid batteries.
    The question is simple are you getting return on your investment replacing lead acid with a drop in lithium battery ... I pay R 130 -210 for 7 amp/hr flooded lead acid/gel battery ... R1100 for an 8 amp/hr lithium replacement battery.
    From what I understand ... its the BMS in the lithium batteries which protect and control them ... but it seems the charger settings is just as important.
    planet earth
    Then you have low battery warnings in alarm panels ... would they be the same or do you have to switch off these settings ... 10.5 VDC cut out which should be ok because the lithium battery cuts out at 10 VDC.
    I doubt the alarm companies are going to upgrade their systems to lithium anytime soon ... it means they will have to redesign PCB's ... at a cost ... I beleive whoever change first will take lead the market.
    So another solution will have to be found ... soon ... and who ever finds the solution first will win the race ... we are taking about a huge growing market ... crime increases by the day.
    It is good business for us when load shedding hits ... at R550 -850 to pop off 2 wires ... slip the new battery into place and drop the old one off at the taxi rank for sale at R50 ... it quick money in the back pocket ... but customer are getting tired of it.
    For now everyone is happy ... winter is almost here ... the question ... are we gonna start replacing batteries soon.
    Andromeda (11-May-21)
  1. Boom there goes the batteries
    Last Post: 10-Feb-20, 03:24 PM
  2. Car fridges and batteries?
    By Houses4Rent in forum General Chat Forum
    Last Post: 14-Mar-16, 11:34 AM
  3. [Question] who recycles UPS batteries in JHB?
    By SilverNodashi in forum Technology Forum
    Last Post: 27-Sep-10, 11:46 AM
  4. [Question] Rechargeable Batteries - Li-Ion?
    By irneb in forum Technology Forum
    Last Post: 27-Nov-08, 08:21 AM
  5. Guns are out and Acid is in.
    By Peter M in forum General Business Forum
    Last Post: 13-Jun-06, 02:44 PM
