NO it hasnt ... its just got worse.
Pump stations worked efficiently and were designed and built to a standard ... now the shyte runs everywhere.
roads were re surfaced not patch patch patch.
the infratructure is deteriorating at such a rate that they having to use some the money to try repair ... a water piper is repaired in front of house number 6 ... two days later its leaking in front of number 10 ... the next day the same water leak again in fornt of number 6 and so the cycle goes around and around until eventually the 100 m stretch will have more joins than the next 5 km ... unitl it starts breaking and around and round we go.
on the freeway i travel everyday ... the trucks keep the bush from growing right across the road... some of the offramps the space is only wide enough for a car ... you havent been able to see the sighns since 2010 ... the only time you get to see the orange line ... when a truck doesnt make the corner ... its cuts the bush right back
