Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: How to terminate LED lights with a short tail
    planet earth
    My thoughts .. please feel free to add your thoughts or regulations ... this is a discussion ... and feel free to add the correct terms which should be used.
    Fit a "junction box" next to the fitting and connect the wires using a a connector.
    The "connection" should be done in a manner that is quick and simple to disconnect and reconnect ... ie wago 221 or connectors block of sorts.
    however to "extend" the wire to reach the "junction" box were the light fitting connection will be done ... not the same thing as the connection point ... I dont see why ferulles and sleeving cant be used.
    What about using a plug connector ... something like a kettle plug or the like (just smaller) ... the smart peoples brains are racing to come up with a cost effective means to overcome this issue paying R65 for a light and R65 for a connector just doesnt make economical sense ... R65 for the light and R6 for the connectors makes a lot more sense.
    Apparently the guys at Pioled do read these threads ... so my advice ... get smart and find a solution to the problem you guys have created ... or manufacture your fittings with a proper termination point.
    I dont know if people from Radiant read these threads but they are the reason I have a problem ... with their ridiculous 100 mm tail provided on the flood lights.
    planet earth
    This would be ideal if my pipe joint was legal.
    You could take it from being a maintance free joint (using ferulles and heat shrink or insulated ferrules) ...and turn it into a connector box ... if i compare to the cable joiner selling for R116 below ( a piece of pipe with a gland on each side) we ticking the same boxes.
    https://www.lightinthebox.com/en/p/i...yABEgLwOvD_BwE
    https://www.youtube.com/watch?v=y98v..._channel=efixx
    Mar 2010
    These thing rock....although they are very expensive
    https://deutschconnectorstore.com/
    “Why, sometimes I've believed as many as six impossible things before breakfast.”
    ― Lewis Carroll, Alice in Wonderland
    planet earth
    planet earth
    planet earth
    So many options ... just no in SA
    https://www.youtube.com/watch?v=8ABf...el=WAGOLimited
    Mar 2010
    Very nice
    Mar 2010
  9. #9
    planet earth
    I use a lot of wago connectors ... pity they are very expensive ... i buy them form AC/DC when they go on special.
  10. #10
    Mar 2008
    Nice. But not in S.A.
  1. Short Courses ?
    By HR Solutions in forum General Business Forum
    Last Post: 17-Jul-17, 04:57 PM
  2. FSB Licence - Short term
    By sterne.law@gmail.com in forum General Business Forum
    Last Post: 11-Oct-16, 05:43 PM
  3. Short run CD Calendars
    By IanF in forum Marketing Forum
    Last Post: 27-Sep-08, 12:50 PM
