Results 1 to 3 of 3
Thread: Link installed Pastel help so that F1 will work
    Bronze Member michellepace's Avatar
    Oct 2018
    Question Link installed Pastel help so that F1 will work
    Hello,
    This is a Pastel question but I am hoping that someone else has faced this problem and found the work around. Pastel version isntalled: Sage 50c Build 19.2.2 (also known as Pastel version 19). I pushed F1 to bring up the help documentation and got the below message that I need to install the help application. So I went to http://pastelupdate.sagesouthafrica.co.za/#download, closed Pastel, and installed Sage50cHelpFile[1.0.0].exe. I then opened Pastel once again and pushed F1 hoping the relevant help screen would appear. But it was not so, I get the same message as shown above. I have checked add/remove programs and there it is - installed (see attached screenshot).
    Question:
    Does anyone know how I can "link" the installed pastel help file to pastel so that F1 will work like it should?
    As always, thanks in advance.
    Michelle
    Oct 2018
    To add, I have this unchecked and the installed help still does not come up:
    Aug 2018
    Normally reinstalling the help file and selecting the Pastel19 directory as the install directory clears up the issue.
    As a short term solution, browse to Pastel19\Custom\Language and open the ENGPARTNER.chm - at least you can access the help from there.
  1. VAT changes work in Pastel BUT...
    By Craig Lester in forum Accounting Forum
    Last Post: 20-Apr-18, 09:32 AM
  2. [Question] Can plumbing pipes (copper etc) be installed next to and behind my DB & across my conduit?
    By ACEsterhuizen in forum Electrical Contracting Industry Forum
    Last Post: 22-Jan-16, 09:15 AM
  3. Generator installed before council meter
    Last Post: 12-Nov-15, 06:18 AM
  4. How does Pastel link a Supplier Return to a Supplier Invoice?
    By Leigh Peiser in forum Accounting Forum
    Last Post: 27-May-14, 02:03 PM
  5. Replies: 2
    Last Post: 28-Jun-12, 09:23 PM
