Results 1 to 6 of 6
Thread: Solar power panels
Hybrid View
    Jun 2015
    bronkhorstspruit
    Solar power panels
    Hi everyone ,
    Can someone please assist in calculating the solar power system wattage for me , am using almost 19.5kwh per day of eskom electricity at home in the villages and now would like to change to solar system. so my question is how do i calculate the number of solar panels needed fo the system and charge controller size as well as battery bank size.
    Regionald
    Another important question - what is your peak power at anytime of the day?
    Do you want to go off grid or supplement usage with solar?
    How much money do you expect to spend?
    Single or three phase?
    What about your geyser/hot water heating, is it part of your daily consumption?
    These questions are relevant to give you a worthwhile answer.
    Nov 2019
    Alberton
    Solar estimating
    I have read that you can take the 20KWH per day and divided by 6hours of sun shine = 3.3KW of panels. But solar losses is about 30% so you need to add 30% of panels to deal with losses that gives you 4.2KW of panels.
    So 13 x 330W PV panels should do as it gives you 4290Watt. Than to choose a inverter that can handle the PV input of 4290W (I would think 5KW should do if your maximum load is not going to exceed the 5KW inverter). Now choose batteries that can take your load through the night without draining your batteries more than what the manufacturer recommend otherwise you will loose your warrantee. I use small cheap batteries that I replace every two years because I hammer my batteries during the night and they will only make about two years life, for me the warrantees are not worth the cost of paying about 4 times more for long life batteries. But that is your personal choice and affordability. (On your system I would think about 400AH x 48V might do, if you don't run geysers, stoves and pool pumps during the night. (Make 14 x panels as 13 is a odd number to connect strings, this is how I calculated my system and hope it guides you in the right direction)
    Dave A (25-Nov-20)
  5. #4
    Jun 2015
    bronkhorstspruit
    thanx for your assistance
  6. #5
    Dec 2019
    Austria
    Hi. I would advise you use the solar panel calculator.
  7. #6
    Feb 2023
    San Francisco
    Hope my advice is still helpful. To calculate the wattage needed for your solar power system, you'll first need to determine your daily energy usage in kilowatt-hours (kWh), which you've already done at 19.5 kWh per day.
  1. [Opinion] Cape Town residents have 3 more days to register solar panels with the city – or else
    By AmithS in forum South African Politics Forum
    Last Post: 28-May-19, 01:54 PM
  2. Replies: 1
    Last Post: 04-May-18, 06:09 AM
  3. solar power inverter issues
    By markthespark in forum Electrical Contracting Industry Forum
    Last Post: 04-Aug-16, 09:38 PM
  4. Replies: 3
    Last Post: 09-Jul-09, 01:46 PM
