Hi All,
Please have a look at this setup (Attached) and if possible suggest what would be the best solution, if I have to install a Genset.
a Bit more info: No Bulk Meter installed, Germiston Wadeville (If By-Laws are Applicable) 3 x 3 Phase Meters Installed
I had quite a heated discussion with a Electrical Engineer, who suggested we just connect all the meter outputs in Parallel to supply the Genset and then supply the building from Genset. I believe this to be incorrect, but couldn't find the regulation applicable. Is this type of connection acceptable or not. And if possible point me to the correct Reg. that states this. "Show me where it's written in SABS 10142"was his argument to me.
Thank You in Advance
Frixter
