Results 1 to 3 of 3
Thread: Pastel Partner SDK and Projects
    Mar 2019
    Cluj-Napoca
    Dear TFSA community,
    Been using the Pastel Partner SDK for document import succesfully.
    Now I need to add a Project code to the Order lines. Is it possible?
    In which database file I can find the project's Code and Description fields?
    Also, in the DefineDocumentLine() function of the SDK i did not see a field that might contain the project code. However this code can be added from the Pastel Partner UI.
    Please see screenshot below:
    Thank you,
    Aug 2018
    The Project Codes used to be called cost codes - haven't been updated in the DB as far as I remember.
    Table - CostCodes
    Files - accjcode.dat
    Fields JobCode and JCDesc
    In HistoryHeader and HistoryLines you will be looking for "CostCode" - defined as CHAR with a size of 5
    QuickTrader (12-Mar-19)
  4. #3
    Mar 2019
    Cluj-Napoca
    Great answer Kevin.
    Thank you!
  1. [Question] Pastel Projects
    By Mel123 in forum Accounting Forum
    Last Post: 18-Jan-17, 12:08 PM
  2. Pastel: Moving expenses between Projects
    By TravisZA in forum Accounting Forum
    Last Post: 08-Mar-16, 01:17 PM
  3. [Question] Pastel xpress projects in purchase returns
    By Tanja Reinhardt in forum Accounting Forum
    Last Post: 23-Feb-16, 02:53 PM
  4. Pastel - Projects - Please Help
    Last Post: 03-Nov-15, 09:10 PM
  5. Pastel Xpress 12 Projects
    By xpressnewbie in forum Accounting Forum
    Last Post: 28-Mar-14, 06:43 AM
Tags for this Thread
