Originally Posted by
GCE
I have been the employer stuck on the supposedly wrong side of UI -19 forms - It is not all the employers fault as UIF seem to have lost info when they changed systems years ago.Also had an issue where the last digit of the ID number was changed back in 1994 with an employee which was a nightmare to sort out.
I faxed forms , emailed forms , spoke to people in an attempt to help my guys with no results.
With the "new"( been quite awhile now) , electronic submssions system there do not seem to be problems - We have just had it with the older employees
The best way to solve the problem is to insist at the UIF that they assign a case officer to your case as your previous employer has committed fraud by deducting and not paying across.
Once the case officer is assigned it is a lot easier as an employer to sort out the admin with somebody that has to actually show a result.
As the employee you should then see the benefit,
Speak to your previous employer, depending upon your relationship , and tell them what and why you are going to do the case officer bit.
Having my guys report me to UIF and insist on a case officer has been the only way to deal with past employees and UIF issues .The case officers come around to the office with a Work Scheldue form that has to be completed as well and everything seems to run a bit smoother.
The lost 2 months can only mean that they do not have your full term of employment registered on there system .Or they are trying to tell you that they cannot pay you out for the past 2 months but it just means that you will be paid for an extra 2 months at the end.
Best of luck, sometimes talking to the brick wall next to you will be more responsive.
