Results 1 to 6 of 6
Thread: ELEVATED VOLTAGE TO NEUTRAL ABOVE 50 V -NOTICE OF POTENTIAL DANGER
    Apr 2017
    Boksburg
    Hi, guys ,
    According to SANS 10142 . When testing the elevated voltage to neutral exceeds 50V , you have to disconnect the supply and notify the supplier . Is there any particular form to be filled in to notify them ? If so , where to I get one ?
    regards
    If it's a fault with the supply then call the appropriate supplier on their fault report line and report it if it's a supply fault, or get the customer to phone it in.
    What type of supply is it (TNCS, TNS, TT)? What voltage was the neutral at? What tester were you using and did you isolate the installation from the supply during the test?
    Apr 2017
    Boksburg
    Thanks Andy
    I have not yet come across this type of a problem . I was just asking in case I come across such as an electrical
    regards
    Quote Originally Posted by Tshepo Mokoena View Post
    Hi, guys ,
    regards
    You can use a photocopy of Annexure H of SANS 10142-1 (page 318 in edition 2.0).
    And get a reference number from the supplier for your report to CYA.
    Apr 2017
    Boksburg
    Thanks Gentlemen
    Gold Member Sparks's Avatar
    Dec 2009
    It is a good idea to befriend the head of the technical department of your local supplier. On the few occasions I have had this situation, I phoned him from site, informed him of the situation and he had a team dispatched the same day to rectify the fault. When a team was in the area I have even waited for them so I could do confirmation testing before leaving the site.
  1. [Question] Neutral split
    By Hotspot in forum Electrical Contracting Industry Forum
    Last Post: 10-Jan-18, 07:10 PM
  2. Elevated voltage on supply neutral measurement
    By PaulG in forum Electrical Contracting Industry Forum
    Last Post: 05-Mar-16, 07:45 PM
  3. Neutral leaking 220V to Earth
    By Etienne Swanepoel in forum Electrical Contracting Industry Forum
    Last Post: 19-Oct-14, 07:37 PM
  4. 3 core cable running 2 phases and neutral is OK?
    Last Post: 09-Jan-12, 07:44 AM
  5. Difference between: Power factor correction, Voltage regulation and Voltage stabisizi
    By BigRed in forum Electrical Contracting Industry Forum
    Last Post: 08-Feb-10, 09:29 PM
