Results 1 to 6 of 6
Thread: Old cleat system earthing.
    Apr 2016
    Hi all
    Some advice required.
    If one has an old cleat system where live and neutral are run to lighting points via cleats. There is no earth to the lighting points or light switches.All earths are connected via earth strap to the black enamel steel conduit that runs to the light switch boxes . There are no other earthing points.If a fan is to replace a light point an earth will be required.Where would one obtain an earth from for the fan.
    Sent from my HUAWEI VNS-L31 using Tapatalk
    Is it the old rubber insulated open wiring?
    Apr 2016
    Not sure if rubber but it is insulated.Could very well be rubber.At one section the insulation is giving of an acidic smelling goo.
    If you install a ceiling fan you're installing a fixed appliance which will be classed a fundamental alteration to the circuit. As such the circuit is then required to be made compliant by todays standard, not the standard it was installed to. I don't see this circuit being compliant unless it's completely rewired. See this thread for further opinions. https://www.theforumsa.co.za/forums/...l-installation
    Also what about RCD requirements?
    Apr 2016
    Thanks Andy .With you on that one. It's difficult all the customer wants is a fan.
    Apr 2016
    The lights are on RCD(Earth leakage) circuit.
  1. Earthing
    By TECHNICIAN 810 in forum Electrical Contracting Industry Forum
    Last Post: 04-Apr-23, 04:53 AM
  2. [Question] Cleat wiring in Electrical installation
    By shnzimande@hotmail.com in forum Electrical Contracting Industry Forum
    Last Post: 12-Dec-17, 10:59 AM
  3. Box earthing
    Last Post: 13-Mar-17, 06:36 PM
  4. Earthing and the CoC
    By WallyL in forum General Regulatory Compliance Forum
    Last Post: 20-Jan-11, 12:06 AM
  5. New demerit system-New driving points system hits the road
    By Candy Bouwer in forum General Business Forum
    Last Post: 23-Jul-09, 06:51 PM
