Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Quickbooks, stock and serial numbers
  1. #11
    Let's tackle this a slightly different way, whilst I've got time to go into more detail.
    What Yvonne has referred to is the ability to create custom fields. However, these custom fields have limited functionality and are only available in certain areas. For example, you can't do a sort or search on a custom field. But that doesn't mean you can't achieve that. If you generate a report which includes the custom field, you can export to a spreadsheet and then sort or search the data to your heart's content.
    It also means that the custom field information will not be carried through the stock management system. i.e. If you capture serial numbers as the stock comes in, you can't draw (or insist on selection) of a specific item indicated by its serial number. The work around would be to create a separate item record for each item, but that is going to be messy i.m.o.
    Ultimately, you need to identify your critical control points.
    If you are trying to identify lost stock items, you are going to have to record serial numbers at both entry to your stock (capturing bills) and exiting your stock (generating invoices).
    If you are trying to identify who bought which item (identified to serial number) and when, you need only capture the serial number in a custom field on the invoice.
    The alternative, as I mentioned first, is to purchase a POS (point-of-sale) or a stock management bolt-on system that has the functionality of tracking serial numbers from entry to exit of the system. This is essentially a parallel process which reduces duplication of data capture - a big part of going with integrated software solutions in the first place.
    These bolt-ons do exist. It has become a lucrative support industry that adds custom solutions to the fundamental accounting platform provided by Quickbooks. But as pointed out, being quite specialised and (unfortunately) we need to purchase EU based versions as the USA bolt-ons are not compatible, they are fairly expensive in a typical micro or very small business environment. Quite commonly the EU version of an application is near double the cost of the USA equivalent.
    The problem seems to be mainly one of scale - there are simply way more customers in the USA and amortisation of the development costs is spread over a bigger customer base.
    There are two particular bolt-ons I've been looking at quite closely - one to handle multiple stock centers (which has the functionality Duncan is looking for among other things), and the other is a rather sweet scheduling and CRM solution.
    To cut a long story short, there is a fairly simple work around using custom fields, but it would be more a parallel system than an integrated solution.
  2. #12
    Quote Originally Posted by dsd View Post
    I don't quite follow
    That is if you are generating serial numbers. You create a control field (commonly the last digit) that is determined by applying an algorithm to the preceding numbers. It ensures that if there is an error at data capture time, there is a 1 in 10 (if using numeric) chance that the system will still accept the number entered as valid. Perhaps even less of a chance I guess if the error is merely one of the digits.
  3. #13
    Silver Member Graeme's Avatar
    Sep 2006
    Check digits
    These are extra digits added to the reference number to check that the ref No has been stated correctly; ie without wrong or transposed figures. Say the ref no is 1234567. Add 1234 = Total 10. For the figures 567 to add up to a number ending in 0, the figure 2 must be added: 1+2+3+4 = 10, and 5+6+7+2 = 20. Both end in 0. Check digit is 2. That is a grossly simple and not foolproof example; in practice a rather more complicated routine would be used. If you wish to avoid unauthorised compilation of account numbers, diabolically complicated routines may be used to establish the check digit (or alpha); I doubt if you would ever figure out what routines the banks use for account Nos. Sometimes the check digit is preceeded by a dash. The beauty of computers is that these check-digit calculations are done in a flash.
    Years ago I wanted to build the National ID Number routine into some software I was writing and in my then naive state I phoned Pretoria to ask them what their routine was - the official I spoke too went bananas - complete sense of humour failure! I thought they were going to come down to Durban and arrest me!
    Whenever I wrote software I always used to program in a routine that would reject an incorrect reterence number upon attempted entry.
  4. #14
    Feb 2008
    Quickbooks
    Duncan - I have had the exact same experience with stock in quickbooks in 3 different versions. The problem I have found as well is that quickbooks also does a average costing on my goods and I needed a Point of sale package that gives me exact codes and FIFO (first in first out) costings and codes. I have found a point of sale package that generates its own bar codes that you can set at a very reasonable cost, and now i am just doing the accounting side with quickbooks. The company that has got this point of sale package if you are interested is at the following link www.goldencreations.co.za. Then I looked into the new Microsoft Accounting 2007 and I am very impressed because it will give me everything in one package. The only problem is it is not released or have support for SA yet. I am just waiting for that.
  5. #15
    Quote Originally Posted by Gillette View Post
    Hmm. Are you sure that's right?
    When you generate a stock report, it does give an average cost value and a lastest paid value. But when the item is expensed at sale, surely the FIFO principle is applied in calculating the expensed value for that transaction?
  6. #16
    Feb 2008
    Quickbooks, average stock calculation
    Dear Dave
    I have just spoken to Quikbooks head office and they told me that as soon as there is a difference on your costings per item, Quickbooks will invoice it out as average costing on you cost of goods side. Now I don't know if they are correct and as far as I can see on my 2006 Pro package it is doing that. They also informed me that this is the way quickbooks operate. That is why for 4 months now I have been researching other packages and so far it looks like Microsoft Accounting 2008 is giving me what I am looking for because it works on a FIFO or LIFO system and I am still investigating it further.The only problem so far is that they don't have the SA version yet for our VAT and Rand value system and I have a problem with there customizing of there sales receipt and invoice templates.
  7. #17
    Thanks for following up on that, Gillette. I'm going to have to give some thought to the possible consequences of that.
Tags for this Thread
