Results 1 to 2 of 2
Thread: Hot water problem
    Aug 2017
    Hot water problem
    About a month ago, my geyser tripped my main leakage switch on the circuit board. A plumber came and replaced the element and thermostat and an electrician came and bypassed the municipal geyser /electricity setting.
    Ever since, I only get about 3 minutes of hot water, after which it progressively goes colder. In about 6 minutes it's only child water coming out.
    The element and thermostat has been replaced twice and the pressure valve outside my unit as well. There doesn't seem to be a leak anywhere either. Yet still my problem continues.
    Any advice would be appreciated since the plumbers are all at a loss as to how to fix this. Is this a electrical problem? A geyser problem? Please help?
    Quote Originally Posted by Nucleo View Post
    ............and an electrician came and bypassed the municipal geyser /electricity setting.............
    I don't understand this part, can you explain exactly what the electrician did.
    It sounds like one of 3 things is happening.
    Either the thermostat isn't working or isn't set properly and it's cutting out much too soon.
    Or there's a power problem like a burned wiring connection causing the geyser to get intermittant supply
    Or there's a problem with hot water constantly flowing either through a tap, pipe leak or a TP valve leak. The TP valve leak is a good one because it usually flows through a pipe into a gutter where nobody can see it.
    TP valve; Click image for larger version.
    flaker (08-Aug-17)
  1. Water Solution available
    By Electrode in forum General Chat Forum
    Last Post: 12-Aug-16, 06:48 AM
  2. Water certificate
    By Houses4Rent in forum General Chat Forum
    Last Post: 01-Feb-16, 09:44 PM
  3. No Hot water
    By jkamuz in forum Electrical Contracting Industry Forum
    Last Post: 25-Sep-15, 10:08 PM
  4. Need some help with JHB City Water
    By Dave S in forum The Whistleblower Forum
    Last Post: 16-Sep-13, 07:12 AM
  5. [Question] water supply
    By murdock in forum Consumer Protection Act Forum
    Last Post: 07-Oct-11, 03:02 PM
Tags for this Thread
