Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Earthing improvement products and ideas
Hybrid View
    Jul 2015
    Cape town
    Hi All
    I'm doing a new home installation and struggling to get a good earth.
    There is a drought in Cape Town right now and it's not helping
    The plot seems to have solid rock everywhere soon as I go more than 1m deep.
    I have installed a copper earth mat below the foundation, used lots of bare copper in the Trench to my wc1 box and knocked in two pathetically short earth spikes about 1metre deep.
    Resistance is still way out of specification.
    Auzzie sparks reckon I should use a jack Hammer to knock down the spikes but I doubt I will penetrate the rock so I am looking at possibly having holes drilled about 6metres x 3 for earth spikes and then filling up with bentonite clay.
    However, I'm not sure it's available in South Africa and I'm also not entirely sure who I contact for the drilling. Core drillers?
    I have spent most of my time working in industrial panel wiring and earthing is not something I have vast experience in, but I guess it's when you have issues like this that you really become *experienced*
    Yeah, earth impedance in some areas of Cape Town can be a problem. What impedance readings have you achieved so far with your short earth rods, earth mat and the trench? What's your target earth impedance? What's you financial budget?
    On the tricky installations I usually connect to any structural steel in the building or even reference meshes in the slabs with a welded stud, just make sure you clearly mark any connections as being electrical earth. You'd be surprised how effective slabs and structural Ufer earths can be.
    The problem with multiple short rods, especially on a domestic plot, is that you get overlapping areas of influence which makes it less effective than a single deep rod, eventually you just run out of space. Also with a deep rod you're more likely to reach the water-table which is a good thing so rather than going with 3x 6 meter rods I'd suggest a single 18 meter rod will give you far better results.
    To answer some of your other questions, yes you do get Bentonite/Marconite locally, it's mined in SA. You could try an SDSMax jackhammer with an earth rod driving attachment but as you say, depending on the types of rocks you might not get anywhere. Drilling a hole is an option, it's expensive and a last resort, I'd suggest contacting one of the borehole companies.
    Bentonite
    Bosch HS1924 SDS Max Earth Rod Driver **Sorry about the price, maybe shop around and also try Hilti and Milwaukee dealers for their version. Atlas Copco do a hydraulic ground rod driver but I can't comment on it because I've never used one.
    Dave A (20-Feb-17)
  4. #3
    Jul 2015
    Cape town
    Thanks very much , I appreciate the advice. I never knew one deeper rod would be better, would probably cost me less to have one hole drilled. Waiting on quotes for drilling.
  5. #4
    Sep 2015
    I have found that you can mix activated carbon and bentonite and this creates a viscous conductor with a large surface contact area in which you can place your grounding conducter (mat / rod). Once wetted, it will stay damp for very long periods. Just be aware that activate carbon can oxidise the copper so try and place some sacrificial copper plumbing pipe around your conductor, not touching it. Bentonite and activated carbon you can buy at at a chemical supplier using our national flower in it's logo.
    @AndyD, with due respect I would suggest you refrain from the practice of:
    The reason is that you are effectively creating a 0.3V battery cell with the steel being the anode and any copper wiring electrically connected to it (and to intentional or unintentional ground somewhere) the cathode. The steel will therefore be eroded over time and the structural concrete member will be compromised. You most likely will be hold liable for any subsequent damage due this practice. Just some good and sound professional advice from my side. We all learn something new everyday!
    A second (and quite interesting) reason is that you are effectively building a telluric current collector ....
  6. #5
    Jul 2015
    Cape town
    And thanks for link, we are blessed to have you guys helping out on this forum
  7. #6
    You're welcome and good luck.
    You didn't say what impedance you've achieved so far with your short earth rods, earth mat and the trench?? And what your target impedance is....
    **Edit** If you're not financially afraid to drill it might be worth exploring a sleeved borehole which could be used as a borehole for water as well as the sleeve being used as an earth rod. Just a thought.
  8. #7
    Jul 2015
    Cape town
    My last reply didn't make it for some reason
    I'm reading about 160ohms.
    Target is 20 or below.
    I did manage to get a1.8metre rod in between gaps.
    The borehole idea Is a great one. I have been quoted 5k to drill one hole do far but still need to shop around a bit.
  9. #8
    Wow, so you've only got it down to 160 ohms with multiple short rods, earth mat below the foundation and bare copper in trenches etc. That's very little reward for lots of work, I'd be clinically depressed at this point if it were me so hats off to you.
    R5K for an 18 meter borehole sounds very reasonable to me especially if it's sleeved. Last time I had to drill for an earth I paid about double that price for a 25 meter hole and that was maybe 7 or 8 years ago so factoring in inflation the price you've got sounds very good to me. When we drilled we hit water at just over 20 meters so we went 5 meters more to accommodate seasonal water-table variations and called it quits. We didn't sleeve but with bentonite and a 5/8ths rod in the hole it gave us about 1.2 ohms Ra reading. It was sub-ohm when we included other parallel paths from existing rods and foundation steelwork etc.
    What is the supply? ie single phase or 3-phase, how many Amps etc? How did you arrive at a 20 ohm or less impedance requirement? Also what earthing arrangement is the supply ie TNCS (PME), TT, TNS ?
  10. #9
    Jul 2015
    Cape town
    I was quoted 5k subject to site inspection for a 6m hole at diameter of round 40mm, no sleeve or anything so might cost more than that for a deeper hole especially when they see the rock
  11. #10
    Sep 2010
    cape town
    what area is it? i found out where ysterplaat got its name from. go down a metre and you hit rock. i also found one long rod is much better than multiple short rods. when you lay the supply cable to the boundary lay 10mm bare copper in the trench. sometimes helps.
    if you can jackhammer through the plaat then 2 x 2,4m spikes on top of each other should do the trick.
  1. Earthing
    By TECHNICIAN 810 in forum Electrical Contracting Industry Forum
    Last Post: 04-Apr-23, 04:53 AM
  2. Good Business / Self Improvement Books?
    By PCAdeJ in forum General Chat Forum
    Last Post: 25-Mar-14, 07:30 AM
  3. How do you come up with ideas for new products?
    By rfnel in forum General Business Forum
    Last Post: 21-Jun-11, 09:07 AM
  4. Earthing and the CoC
    By WallyL in forum General Regulatory Compliance Forum
    Last Post: 20-Jan-11, 12:06 AM
