Results 1 to 4 of 4
Thread: Cooler/freezer room
    Sep 2015
    port elizabeth
    Cooler/freezer room
    Good day all
    I have a question regarding cooler room in a butchery.
    It is wired with a 4mm cable and has a 30amp mcb in db. Should it have a switch-disconector also or is it fine as is? Its protected also by th elcb .
    Thanx
    The cold room would be classed as a fixed appliance so I'd say it should have an isolator switch at the condensing unit unless the MCB in the DB is close enough and qualifies.
    Sep 2015
    port elizabeth
    This butchery has also a 3phase cold room and it is not protected by a ELCB. The client has spoken to his friend in JHB that is a MIE and he said it does not need to be protected by a ELCB. Is this true? I just need to confirm this,rather safe than sorry. Thanx for your input Andy
    Sep 2010
    cape town
    it does not have to be protected by earth leakage relay. if it was plugged in to a socket outlet then it would need to be on earth leakage relay.
    mikilianis (27-Dec-16)
  1. Safe room door
    Last Post: 21-May-13, 07:23 AM
  2. freezer room light fitting
    Last Post: 16-Jan-13, 09:21 PM
  3. Chat-room Propaganda.
    By tec0 in forum Technology Forum
    Last Post: 14-Jul-09, 10:54 AM
