Originally Posted by
Justloadit
Andy, not necessarily, today's equipment are made with SMPS, to maintain low cost, which work of a DC signal. The internal feedback loops with in the UPS, adjust the PWM, so that the voltage required by the equipment is maintained, this is the reason that a SMPS is rated between 95-265V. These SMPS's will work with a pure DC signal, so the fact that the supply is a modified sine wave will have no effect on the equipment. The incoming supply is first inserted through a bridge rectifier to convert to a pure DC signal, which it then uses to supply the equipment.
The only time that a "pure" sine wave is required, is when there are inductive loads involved, such as an electric motor, be it a fridge, pool pump, water pump, microwave, fluorescent lights which use a starter and a choke, very cheap LED lamps which use RC as part of it's PSU.
TVs, decoders and most modern printers will work quite happily with a modified sine wave.
The reason that inductive loads and motors require a sine wave is due to 2 reasons, the first being that the square peak of the incoming wave is on for too long, which causes the iron in the motor to overheat because the motor was designed for a shorter peak. The 2nd reason, is the rise time from zero to peak is vertical, which changes the characteristics of the inductor filter circuit and excessive current will flow causing overheating.
