Originally Posted by
wynn
Also your new thermostat probably needs to be zeroed, quite often they stick when new or temperature is changed, simply turn the little heat gauge indicator all the way to max (You should hear or feel it click) then turn it all the way back to zero (you should hear or feel it click again) before turning it to the desired temperature setting (do this last setting in a single movement because if you stop halfway that may result in the temperature being set at the pause position).
