Originally Posted by
skatingsparks
Just write down ALL test results.
Have folders full of scribbled down test results in my own test sheet which I have kept just in case. The info you put on the COC is not enough. You just put in the worst case scenario for earth continuity? What good is that. If there was ever any dispute I don't think you would remember at what point you tested for that single number. Also with Eskom messing around with things I have had an incoming earth vanish after they dug up the road to connect a new supply and didn't reconnect properly. Careful what you sign people.... It's like signing a document when all the terms and conditions are not checked.
