Page 7 of 7 FirstFirst ... 567
Results 61 to 64 of 64
Thread: Does a stove need to be on an earth leakage?
  1. #61
    There's a good chance from the fault you describe that one or more of the plates has a fault that's causing the earth leakage to trip. Problem is that to prove it you need the right test equipment which is outside the budget of most DIY'ers so you're going to have to get a sparky in to do the testing unless you just want to chance that a replacement plate might fix the problem.
  2. #62
    Gold Member Sparks's Avatar
    Dec 2009
    It's a bit odd, I thought the stoves with spiral plates had the type of temperature controller you describe and the stoves with solid plates click between every different setting. Also, don't the solid plate controls only have 5 or 6 temperature settings?
    Can you attach a photo please?
    Maybe one of the domestic sparkies can give you better info than me, it's not the kind of thing I usually work on so I'm not so familiar with it.
    I agree Andy. Enegy regulators are usually used on spiral plates which is why my 1st thought was that the switch is perhaps arcing causing the intermittent tripping. I have given a list of possible faults which can all be tested for with an insulation tester. One cannot pinpoint the cause without actually testing the stove.
  3. #63
    Jan 2018
    Boksburg
    Thanks for the thoughts guys. My suspicions are that it is the 1 plate arcing. ( the heat controller ). The tripping only happens when this plate is on, and when turning it down from MAX.
  4. #64
    Dec 2009
    Be sure to get the correct switch. I suspect that the wrong type of switch has been used.
  1. Earth leakage trips at night??
    By Jongseun in forum Electrical Contracting Industry Forum
    Last Post: 18-Jun-12, 10:47 PM
  2. earth leakage unit failure
    Last Post: 23-Feb-12, 08:37 PM
  3. Random earth leakage problem
    By BillH in forum Electrical Contracting Industry Forum
    Last Post: 23-Jan-12, 09:37 PM
  4. stove plate
    By murdock in forum Technology Forum
    Last Post: 31-Mar-10, 11:24 PM
  5. CBI earth leakage units
