Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Generator starts while the main power is on
  1. #11
    Oct 2011
    centurion
    Hi All,
    Funny if you forget your ear thing grounding when you do your trade test then you fail well I failed this genny test. After trying everything and nothing blow up I located the people that manufactures the DKG 105 DATAKOM I then mailed them my problem and all that they had to say was check your grounding.
    The main grounding wasn’t connected from the panel to the DB so I connected it but couldn’t give the genny a go because the battery was flat. I’ve just drop the mains the genny starts and after I switch the mains back on the genny runs for almost 2 minutes and then switches off. Who would of thought just an earth I thought it was a bit far fetched but thought what a hell I tried every thing go check your earths connected them and its all good.
    Many thanks for your replays and don’t get grounded
    Dave A (11-Oct-11)
  3. #12
    Great to hear you got the problem sorted out and thanks for the follow-up info.
  4. #13
    Oct 2011
    centurion
    Thanks man hope it helps some one els in the long run,
  5. #14
    Quote Originally Posted by jvan66 View Post
    And along those lines - would you mind if I moved this thread into the electrical forum?
  6. #15
    Oct 2011
    centurion
    Not a problem, Thanks
  1. Main Switch?
    By Sparks in forum Electrical Contracting Industry Forum
    Last Post: 08-Feb-11, 10:16 AM
  2. Consumer protection act starts biting.
    By Dave A in forum Consumer Protection Act Forum
    Last Post: 27-Aug-10, 04:18 PM
  3. Generator usages to run PCs
    By Pieter1 in forum Electrical Load Shedding Forum
    Last Post: 03-Feb-08, 10:21 AM
  4. ANC starts attack on Zille.
    By Dave A in forum South African Politics Forum
    Last Post: 01-Nov-06, 03:02 PM
