Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: gas appliances
Hybrid View
    Junior Member sparkydelux's Avatar
    Jul 2011
    Hillcrest, Durban
    I find it quite amusing that Refrigerattion installers (who use a much higher PSi rating the LPG) are not allowed to install gas. Bear in mind the same principles apply, and both gases can be fatal. LPG Gas, if there is a leak, can be detected quite quick due to the smell and is evidently flammable. refrigeration gases also combusitble and very hazardous.
    If both gases are installed under the same principles, then why cant a fridge guy install gas? Money making scheme?
    My other trade is AC/ refrigeration and I called up LPGSA to enquire but didnt really get an answer. Infact I was more confused than when I originally called.
    What I am trying to say is that if I can deal with pressures of around 200PSI on testing and using Nitrogen etc why cant I transpose the same techniques onto LPG. They use far less PSI and they rely on Jubliee clips as fastening.
    I was stunned to find a guy was going to come and fit my gas connection for R800 and literally fasten 2 jubilee clips. I'd also like to charge R800 for 2 jubilee clips and a bit of spray soap to check. I'm just stunned that these guys think its so involved when its not really.
    BTW, we had (at our family home) a gas installation done on the hob. the guy came out, did his thing, charged and left. It was fitted inside a cupboard next to a 'pot and pan' draw that opened and closed. Anyway, 4 weeks later of opening and closing the draw, we smell gas. The DRAW had cut a groove into the hose and was causing a leak. lucky we caught it or else I'd have no folks left. When they slept they wouldnt have even known. So, for the agro of 2 jubilee clips and relying on someone elses workmanship, I am jubious on the rate they charge and the amount of technical difficulty it involves.
    Hopefully they come out with something that bypasses these installers........watch this space!!
    I was not aware that the 'R' range of refrigerant gas was inflammable.
    There are very few fridges using LPG as a refrigerant, precisely for the reason of inflammability.
    The other point is how many litres of gas in a refrigerator, as opposed to a gas supply for a stove?
    Jul 2011
    Hillcrest, Durban
    Well Lets put it this way. A chiller can hold between 150Kg and 250Kg of Refrigerant. A fridge, couple of KG, A split unit (pre charged about 3.5kg and then top up all depends on run etc.)
    I said combustible and not inflammable.
    I assume ammonia is not flammable?
    Some Info from institutes around the world.
    Definition: A refrigerant that may ignite or burn. This includes butane, propane, isobutane and certain other hydrocarbons. Flammable refrigerants are considered dangerous because of their risks to service personnel as well as the occupants.
    Refrigerant is a flammable substance and is classified three ways: Class 1, Class 2 and Class 3. Refrigerant that is classified as Class 1 is considered to be non-flammable, while Class 2 has a low flammability classification. Class 3 is considered to be highly flammable.
    How is this any different from LPG?
    I now retract my original quote and ammend it to 'Combustible and Flammable'. Learn another new thing everyday.
    Oct 2007
    R800 and ita 4 day course...people dont bat an eyelid to pay...charge that to do a stove connection which includes materials worht R600 and people complain...mmmm
    same as a thermographer...takes 5 days to become a level 1 thermographer...and you dont even have to do the course and you can charge anything from R3500 and up...and please dont tell me it its because of the price of the equipment...my power quality analysing equipment cost twice the price of the thermal imager....so i should be charging R7000 per call out.
    and now you know why a docotr charges R1800 an hour or R18000 a day + because he studied for 5 years
    Well Murdock,
    Get yourself a couple of more certificates, and you can then charge for doing this other work to supplement your income.
    Gold Member Sparks's Avatar
    Dec 2009
    I am also a qualified refirigaration technician and do not know of any refrigeration system with inflammable gas in the system. Sweating on such a system will definately be your last job. The only danger of a refrigerator is shock. As for LPG, I have been using it for years and consider it safer and more economical financially and time-wise provided all the safety precautions are taken. I will never trade my gas hob for an electric one.
    Here's an article from 2009 about the joys of isobutane (R600a) as a refrigerant.
    Dec 2009
    I believe the original post related to a "domestic" gas geyser? The main thing is that whoever installs it needs to be a "responsible" person with safety as his main concern. Not securing a gas pipe where it is exposed to friction is not what a "responsible" person would do. My gas pipe goes through a pipe I put in the ground from the kitchen "island" all the way to the outside.
  1. bathrooms and fixed appliances
    Last Post: 27-Jun-11, 07:03 AM
