Logic, math & statistics puzzle...that holds some wonderful lessons!
  • Christel
    • Feb 2012
    • 361
    #61
    Yes, you're right, sorry. Was being distracted with the "0" that someone suggested and the negative amounts.... then I thought but what about 1 and 3 and 5...?
    • Mike C
      • 2891
      #62
      Also no one suggested fractions!
        • 2680
        #63
        Adrian just needs a series of random numbers for quoting the tirekickers who ask for prices.
        • Marq
          • 1297
          #64
          Any positive number
          • Christel
            • Feb 2012
            • 361
            #65
            Adrian... where are you...? we have 6 possible rules so far... 4 to go.... BUT... can't we adjust "your" rules so that we can get the answer/explanation now... before the weekend starts...
            • vieome
              • 540
              #66
              1. IanF - 10 - Fits rule.
              2. MikeC - 16 - Fits rule.
              3. IanF - 26 - Fits rule.
              4. Marg- 13 - Fits rule.
              5. Vieome- 99 - Fits rule.
              6. IanF - 17 - Fits rule.
              7. Anthony - 31 - Fits rule.
              8. Vieome- 7 - Fits rule.
              9. MikeC - 8 - Fits rule.
              10. Marg- 0 - Does NOT fit rule.
              11. Christel - 48 Fits rule.
              12. Wynn - 27 Fits rule.
              13. Christel- 12 Fits rule.
              14. HR - 18- Fits rule.
              15. HR - 35- Fits rule.
              16. Vieome- 67 - Fits rule.
              17. HR - 1689- Fits rule.
              18. HR - 1245987 - Fits rule.
              19. HR - 3895621 - Fits rule.
              20. IanF - -3938 - Does NOT fit rule.
              21. Christel- 246 Fits rule.
              All the numbers come after 6
                I've had a hell of a couple of days.
                Question
                I have some numbers 2 4 6 and I would like for you to work out what is the rule for the next numbers.
                Tests
                Rules
                1. Christel - The rule is that the numbers chosen by Adrian (2,4,6) was just to get us thinking... but the answer is any number, except for a zero and not a negative number.
                2. HR - Rule is ascending (increasing numbers)
                3. MikeC -One of the rules could be any number greater than 6
                4 - Marq - Any positive number
                Ok, the rule is: Any number after 6.
                Lets look at the tests
                1. Most people went looking for sequences higher than 6..
                Why did you think that the number should be higher than 6...because the sequenced numbers prompted you to do so.
                If I possed the sequence as 6 4 2 I bet that most people would have looed for number lower than 2.
                2. A lot of tests seemed to be purely random - Why?
                3. Christel was very quick to look at the situation in reverse.
                Most people look for a pattern because we are programmed to do so, very few people start with an infinite date set and then systematically eliminate very large data sets working towards smaller sets.
                4. We assume that the data 2, 4, 6 are related to one another in some way (it could simply have ben 2 eggs, 4 wheel and 6 cigarettes, for no reason at all.
                5. Our pattern recognition software takes precedence and try to project the data forward.
                This has very interesting consequences that marketers use...lets say a TV ad said that a chocolate bar cost R2, 3 years ago, R4 2 years ago and R6 last year. We would have predicted the price to be R8 this year, for no other reason than it following a pattern. He now tells you that the chocolate bar is on special and only costs R7. Many people would see this as a bargain even though he never said that it should cost R8, we simply projected the number.
                6. Making rules based of small data sets is very dangerous. An economist would use a small data set to project forward creating a pattern where there is none.
                7. I think that we have to be very careful of our pattern recognition software because it kicks in automatically and often leads us up the garden path.
                • Houses4Rent
                  • Mar 2014
                  • 803
                  #68
                  We are looking for inteligent rules, any number >6 is not intelligent at all. What has this to do with logic, math etc? Not much in my opinion.
                  Houses4Rent
                  083-3115551
                    hmmm....I'll say this much, I will hire Christel in a flash...you, not a chance, your mind is far too narrow!
                    • Houses4Rent
                      • Mar 2014
                      • 803
                      #70
                      I am not for hire.
                      Christel, pick your number and Adrian will hire you for that number.
                      Houses4Rent
                      083-3115551
                        Didn't you find the exercise interesting at all?
                        • Houses4Rent
                          • Mar 2014
                          • 803
                          #72
                          I did, but the outcome/rule was unchallenging. Was there any reason to insult me (without even knowing me) just because I voiced my opinion?
                          Houses4Rent
                          083-3115551
                            I don't believe that I insulted you, I said that I think that your thinking is narrow-minded, that is not an insult, it is simply my view of how you think. Narrow-mindedness is a function of specialization, you are probably a highly specialized engineer that is extremely good at what you do. I think very broad-mindedly but I am totally non-specialized.
                            • vieome
                              • 540
                              #74
                              I was on the right track.
                              Could such a response be because of the very thing the exercise was pointing out, when peoples thoughts align with our own we are like yes, good thinker, when not, we engage pattern software thinking and label to it.
                              • Houses4Rent
                                • Mar 2014
                                • 803
                                #75
                                Its an insult to me and judging from vioeme's comment s/he agrees to a degree.
                                If I would be a narrow minded specialised engineer I would not have changed my career 180 degrees either. Even my engineering education was very broad based which made me a generalist and I did another degree on top in Supply Chain. As I said you have no clue about me so you cannot judge me the way you did. There was and is no need to judge either.
                                Mayeb you should look at your motto "You cannot depend on your eyes if your imagination is out of focus” and live by it.
                                Houses4Rent
                                083-3115551
