EMP501 - Uploading of certificates
  • BvN
    • Jul 2010
    • 15
    [Question] EMP501 - Uploading of certificates
    Hi all,
    I was wondering if someone could perhaps shed some light on a problem I'm experiencing?
    I'm trying to upload a couple of EMP501's (which is late but it has to be done)
    For the purpose of the upload I created a submission from Sage One Payroll (created a .csv file from the information on Sage One)
    When I log onto e-filing and choose the particular EMP501 I click on the "Upload certificates" button on the bottom-right and choose the .csv file for the particular company.
    For each of the companies the following error appears: UIF Reference Number Mismatch : Format check failed - (SDL (2022) and UIF (2024) Reference Numbers don't correspond).
    I checked the numbers thoroughly and can confirm the correct registration numbers are used, so why the error?
    I would appreciate it if someone could perhaps assist in getting this resolved.
    Thank you.
  • Achmat Kazie
    • 9
    I have not used the efiling option to submit the EMP501.
    I have found that the SARS EasyFile software was the easiest method to submit the EMP501. Sage One should allow you to export the IRP5/EMP501 data that you would then import into the SARS EasyFile application.
    Hope this helps.
    • BvN
      • Jul 2010
      • 15
      Achmat,
      Thank for the reply. It looks like that is the way to go.
      I was hoping I could avoid having to register each company on a third database (e-filing, Sage One and now easyfile as well)
      Regards.
