Pest Control - Find Out How to Prevent Infestations
  • jdizon
    • Jun 2010
    If you are considering getting pest control services for your house, you should first think about what may have caused the bugs to be attracted to your home in the first place. Sometimes you can't help it, perhaps because they are just common in your area, or maybe close neighbors in an adjacent apartment have an infestation that carries over to yours. However, there are usually risk factors that you can prevent so that you are less likely to get bugs in the house.
    You probably already know that garbage attracts unwanted visitors often. However, most people assume theirs is safe when it is put away, such as under the sink. If you have no lid or leave it open, though, you may still get pests like roaches, flies, ants, and more getting into it because they can smell it and have easy access to it. This may also lead to pests under your sink, eventually coming into the rest of your house. Try to cover your garbage to avoid this.
    Make sure your house is sealed up well. Crawl spaces that are not well sealed, such as attics, and tiny holes in other areas of your home can invite bugs in. Some structures have holes or gaps that you cannot see because they are hidden down low under shelves or in linen closets, so inspect your house to make sure this is not the case. You will not only save money on pest control this way, but you may also save cash on your utility bills since less air will be coming in or leaving through the gaps.
    Get rid of any wood piles or collections of old branches and shrubs, as pests can hang out in them. Carpenter ants and even termites may feel right at home in such areas, and can end up entering your residence or causing extreme damage to it from the outside. If you need to keep piles of lumber to build a fire, store them away from the structure to avoid making it easy for insects to enter.
  • charlesibsch
    this one may
    it's an significant ----to remove pest....agreed there are many ways....do it yourself or contact co....If any one searching organic pest control service, termite control for commercial, residential, natural pest control and domestic pest control they will find in Australia.
    • pcspestcon
      • Jun 2023
      • 11
      Pests and rodents aren't simply a nuisance - they can severely affect your health and the health of your family. This is why bug and insect prevention is critical in protecting homes, businesses, schools and any other place where human beings live, work or play from a pest infestation.
      Here are some general tips to prevent household pests and rodents from entering your home:
      Seal cracks and holes on the outside of the home including entry points for utilities and pipes.
      Keep tree branches and shrubbery well trimmed and away from the house.
      Keep basements, attics, and crawl spaces well ventilated and dry.
      Store garbage in sealed containers and dispose of it regularly.
      Repair fascia and rotted roof shingles; some insects are drawn to deteriorating wood.
      Replace weather-stripping and repair loose mortar around basement foundation and windows.
      Store fire wood at least 20 feet away from the house and five inches off the ground.
      Call a qualified pest professional for additional advice and treatment if necessary.
