If you install a "drop in" lithium battery to replace your old FLA or gel battery, do you set your charge rate for a lithium battery or FLA/ gel ?
If you are replacing an FLA/gel battery with a drop replacement, you would leave the settings the same.
As we all know the charge/discharge characteristics of a lithium battery is not the same as FLA/gel, just like the regulations wouldn't be the same for battery placements.
IF you buy a trolley type inverter and upgrade to a lithium drop in battery, could you still position the trolley inside the lounge next to the TV cabinet ?
Would the lithium battery capacity regulate the location of the battery, for example if there are 2 x 100 amp/hr batteries used in a 24 V trolley?
At what capacity would you consider the type of battery and risk used inside the house?
Dropping an 18 amp/hr lithium battery into your bedroom cupboard to replace the old 18 amp/hr gel battery a much higher risk ?
The big question is at what point does the lithium battery because a risk for insurance cover. It seems insurance companies are getting smart and auditing locations where lithium batteries are installed, they dont seem to care where you install the battery, they ar emore concerned about the fire suppression and type and size of fire extinguisher. You are in for a rude awakening when you see what they cost.
