We all know that single phase inverters require a double pole isolator for the input and the output and the ATS must be a double pole.
The question, regarding 3 phase inverters input/output output:
We now know that a Sunsynk inverter doesn't have an ATS, but rather a common busbar system which drops out the grid supply, (islanding mode).
Some inverters dont have a built in method for islanding mode, but rather a box on the wall, referred to as a gateway, which should have ATS.
The ATS or islanding mode contactor 3 pole or 4 pole?
The inverter input isolator/mcb must be 3 or 4 pole?
The inverter output isolator/mcb must be 3 or 4 pole?
The input isolator/circuit breaker feeding the inverter - 3 pole or 4 pole?
The output
The output
