Inverters
  • Sparks
    • Dec 2009
    • 909
    Inverters
    Can anyone shed light on these products? Are they Fong Kong?
    You pays your money, you takes your chance. The problem with all these inverters that are flooding the market is that many of them have no history to judge them on so it's down to the suppler you purchase from whether or not spares will be available and whether or not they'll be answering their phone in six months time when they've sold their container load of stock.
    Your guess is as good as mine I'm afraid Sparks.
    • Sparks
      • Dec 2009
      • 909
      Thank you Andy, if nobody could post a favourable comment I was hoping a recommendation might get posted. I have been requested by a pharmacist with a small load and a salon with a bigger load to provide backup power systems. Being within shopping centres they prefer to not have generators.
        My formula so far with the numerous small (1-10kW) load shedding back-up installations we've been doing is to stick to known good brands and known good wholesalers. I can't afford the time and expense of warranty claims even if the wholesaler is providing a replacement unit so I've only used the Victron for the high end installs and the Axpert for those on a lesser budget. There was one job where the customer specifically requested an 'Outback' inverter and it seemed okay as well but it wasn't a cheap option. I've drawn a line at that and any request on a very low budget and looking for small camping type inverters I've declined to get involved. There are lots of cheaper Far-East rebranded options literally flooding the market but I've avoided them like the plague and will continue to do so I'm afraid until such a time in maybe a year or two when it's possible to judge them on their past performances. If you do install it lets us know how it goes, it's always great to get first-hand info on products from guys in the field rather than salesmen with a vested interest in moving them.
        • Sparks
          • Dec 2009
          • 909
          Thanks Andy. Here in PE the load shedding has not been that severe that the suppliers have jumped onto the inverter bandwagon. Voltex is the 1st one to make the move and has decided to start off with a 1.5KVA @ R8 000excl. I have been googling and have sent off numerous emails countrywide for catalogues' but, any feedback from guys already using specific brands and recommending them will help deciding what to go with, especially if known duds are exposed.
          BTW since its inception I have only been without power 2 or 3 times the longest of which was maybe 15minutes.
            I am getting a sample of a new range of 600W, 1000W, 2000W and 3000W of pure sine wave inverters in about a week , and will be putting it to a good soak test to get a feel of the units.
            If I am comfortable with the outcome, I will post here.
            • ACEsterhuizen
              • Mar 2012
              • 165
              Andy would you then recommend these and what do think about this supplier service and price. Thanks in advance.
              ps. also which deep cycle batteries has a good reputation? Raylite? Willard?
              I know we are not here yet but like elon said...batteries suck. :-)
                The inverter you've linked to is the brand I've been installing as our budget option. I haven't had any issues with them yet, all our installs have been reliable and the inverters have performed as they're supposed to.
                I can't comment on the supplier but the issues I would have with an online supplier is whether or not they can provide technical backup. The problem is that these things aren't like a toaster or kettle where you unbox it, press a button and voila there's toast and tea. These things have a program menu that's fairy extensive, you have to set up perameters that are dependant on the system configuration, the specific type of batteries used and so on. There's almost an infinite number of ways an inverter installation can be specified with different battery types, different solar string arrangements etc so I'd say aftersales and tach support is a must. Maybe phone the supplier with a few tech questions and see how convincing they are before you take the plunge with them.
                I've been using Trojan deep cycle flooded lead acid batteries and they always performed well even on installations where the load has evolved to push the system to the max.
                  Originally posted by Sparks
                  ....BTW since its inception I have only been without power 2 or 3 times the longest of which was maybe 15minutes.
                  Maybe one of your neighbours isa politician who's got some sway over the load shedding schedule
                  My home inverter system had its twenty eighth load shedding birthday yesterday at 6.01pm - 8.14pm. It's been installed since 14th Feb and it's given me 3863 minutes of back-up power (63.93 hours) so far. To be honest it's been worth every cent it cost me. I believe there's some areas of JHB that are far worse off as well sometimes getting loadshedding twice a day or 4 hour periods instead of the 2 hours we're getting in Cape Town..
                  • ACEsterhuizen
                    • Mar 2012
                    • 165
                    Thanks Andy, can you please recommend a supplier? pm if you want pse.
                    My inverter sometimes works happily, sometimes it screams, but mostly it just sits there depressed, I think it is bipolar....
                    • cje
                      • Jun 2015
                      • 3
                      Hi Sparks, can u assist with following pls:
                      How does one wire an inverter thru the DB (assuming domestic installation and via a change over switch). .same as you would with a generator? I foresee a problem with the socket that is charging the inverter..
                      Your assistance is appreciated!
                      • ExpatfromCT
                        • Jul 2015
                        • 3
                        Advice please. I bought a 600w pure sine wave inverter/charger to power LED down lights(220v) during load shedding with a 105Ah deep cycle battery. It has a "bypass transfer part", as quoted from the manual and a 3 stage charger. Would this mean that I could connect the battery to the inverter, plug it into the mains with the supplied three point plug top and connect the AC outlet directly to the breaker marked "lights" inside the DB? When load shedding happens the lights should remain on and when supply from Eskom comes back on the inverter should cut supply to the AC outlet and only recharge the battery?
                        • SilverNodashi
                          • May 2007
                          • 1197
                          From a technical poiny of view, sure you can. Just as long as you follow all the requires SANS regulations (i.e. using the right wiring, running it through conduit, putting up extra labels for this purpose and an indication light showing there's extra power to the DB board when Eskom is off).
                          And you would need to "isolate" the light circuit(s) neutrals so it's not mixed with the plugs.
                          P.S. Please don't hijack threads. Rather start a new one
                          • bergie
                            • Sep 2010
                            • 308
                            when power comes back on,there will still be power to the lights and it will charge the battery.
                            • SilverNodashi
                              • May 2007
                              • 1197
                              http://www.gbssolar.co.za/product_pa..._cat=Inverters
                              Most electronics are made in China, Taiwan, Hong Kong, etc. And those which are made elsewhere have parts which still originate from the east. Nothing wrong with that. One that page, I have noticed that the very first one is rather inefficient. Ideally, if you buy an inverter, get a pure sinewave (modified is good for TV, lights, etc. NOTHING with a motor inside) and make sure the VA (or Kva) and W (or KW) are very close together. i.e. 1000VA should be about 800-900W, nothing less. The closer together they are, the more efficient the inverter, and the more optimal the inverter and batteries will work.
