How to Remove - Sage South Africa - from printing on plain paper invoice
  • Lindsay S
    • Mar 2014
    • 19
    [Question] How to Remove - Sage South Africa - from printing on plain paper invoice
    Can anybody advise me how to remove the "Sage South Africa (Pty) Ltd" wording from printing at the bottom of the plain paper invoice please?
    Using Pastel Partner V19.3.5
    Thank you
    Lindsay
  • Neville Bailey
    • 2786
    Hi Lindsay,
    If you have not previously customised the invoice layout, go to Utility...Forms Designer, then open csdocsp.eng under the Custom/Forms folder.
    Scroll down to the bottom of the form file template, and right-click and delete the text box named "Sage South Africa (Pty) Ltd".
    Click on File...Save As and save the modified file into your company folder (you will notice that the file extension has changed from .eng to .enz).
    Finally, click on File...Save As again and change the file name to csdocpdfsp.enz and save into the company folder. The system will use this file when emailing and printing to PDF.
    • Lindsay S
      • Mar 2014
      • 19
      Hi Neville
      Thank you for your detailed reply.
      It worked perfectly and solved my problem.
      Thank you, very much appreciated.
